Water temp #1630069
06/07/14 05:21 PM
06/07/14 05:21 PM
Highland beach Fl
P
poisondart2 Offline OP
P
Highland beach Fl
Hey, which is the preferred place for water temp? In the head or manifold and if in the head would it show a higher temp reading than the manifold.Thanks
Re: Water temp [Re: poisondart2] #1630070
06/07/14 05:38 PM
06/07/14 05:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The head will show higher being its closer to the source
but as a general temp you want it prior to the ratiator
and prior to the stat if running one
Re: Water temp [Re: MR_P_BODY] #1630071
06/07/14 06:19 PM
06/07/14 06:19 PM
Highland beach Fl
P
P
Highland beach Fl
Thanks Mr P. I have no thermostat but was taking the temp from the head and was going to change it to the manifold
Re: Water temp [Re: poisondart2] #1630072
06/07/14 07:59 PM
06/07/14 07:59 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have mine on the intake of the water pump so i can see how much my engine is cooling down when i have the fan running. in the head it will register the hottest temp due to that being the last path of the coolant unless you have a reverse flow.
Re: Water temp [Re: rebel] #1630073
06/07/14 08:01 PM
06/07/14 08:01 PM
Highland beach Fl
P
P
Highland beach Fl
Rebel Thanks
