The "True street car ET" made me curious: How fast...
#1630021
06/07/14 02:46 PM
06/07/14 02:46 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
...have you ever been on NON-sticky REAL street tires? I mean BFG T/A's, etc. What was your car/combo??
Back in the day, we used Pos-A-Traction tires that were 100% legal and into the low-to-mid 12's with a talented throttle foot, until we "stepped up" to McReary dirt track tires...LOL.
Not to exclude them, but we already know how fast the FAST guys are going to Polyglass stuff. Just wondered about the "rest of us".
Re: The "True street car ET" made me curious: How fast...
[Re: Jeepmon]
#1630023
06/07/14 03:55 PM
06/07/14 03:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I had A 66 dart 2.94 open 360 with 318 heads 205 70 14 goodyear Vivas and ran 9.6 1/8 with a best 2.0 60 ft
[Re: cudadoug]
#1630024
06/07/14 06:05 PM
06/07/14 06:05 PM
Posts: 12,125 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Up until a couple of years ago, our local track ran some KOS races on Friday nights. One class was street tire class which meant 275/60 STREET tires. Not drag radials or DOT stuff, just street radials. The Cuda would pull 1.60 60s and run 7.10-7.20 @ 103 +/-. Try as I might, I could never quite crack the 6.0s on those tires. But it run 6.89 on drag radials. 3,450lb 70 Cuda, 499", 727, 3.91s and Cal-Tracs. Got class champion in 09 and 10.
Master, again and still
[Re: Lee446]
#1630034
06/08/14 01:04 PM
06/08/14 01:04 PM
Posts: 4,681 Wichita
GY3
Wichita
71 Cuda that had a very mild 440, 3.23 gears, stock wore out suspension and Futura Super Sport 245's on the rear. Car had a horrible 60 ft. and ran 13.57 @ 104 mph. Great manners and could drive it anywhere.
[Re: GY3]
#1630035
06/08/14 01:28 PM
06/08/14 01:28 PM
Posts: 9,846 MI, usa
dvw
MI, usa
My son had a 65 Belvedere. Stock converter, 3.91 with 255x60 radial T/A's. If you left just above idle it would hook anywhere and cut .010-.020 lights. 12.90@109Doug
[Re: cudadoug]
#1630036
06/09/14 12:24 PM
06/09/14 12:24 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
"have you ever been on NON-sticky REAL street tires? I mean BFG T/A's, etc." I understand where you are coming from with this question, but if the tire is 100% street legal and sticky, why do you exclude them? I went 11.80 in my Mercedes! My 200 Dakota went 13.9's.
[Re: cudadoug]
#1630038
06/10/14 01:10 AM
06/10/14 01:10 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
In 1994 I run 12.16/116.5 with 205/75/15 BF Goodrich lifesaver white wall radials in my BB four door A-body, the best 60 ft was 1.93 and could consistently run 12.2's with 3.23 gears. The engine had a carb shop 3310 vacuum carb, so it was pretty "soft". 10+ years later I tried the very same tires again with the same car, gear ratio etc, this time maybe 200+ hp more. Made three runs but there wasn't any sence. The dominator was way too aggressive. Run best of 11.60/132 with the 60 ft 2 seconds flat.
Plynouth VIP '67 TT IC EFI
