fluid for 904 transmission #162981
12/06/08 09:38 AM
12/06/08 09:38 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Just wondering what the right fluid for a 904 and 727 would be. Ive been told so many things lately about which fluid to use.
Re: fluid for 904 transmission [Re: derekeh] #162982
12/06/08 09:41 AM
12/06/08 09:41 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
most use Dexron III, or Type F here..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: fluid for 904 transmission [Re: GoodysGotaCuda] #162983
12/06/08 09:57 AM
12/06/08 09:57 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
If your mixing with original Fluid, it would be dexron type transmission fluid.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: fluid for 904 transmission [Re: goldduster318] #162984
12/06/08 10:33 AM
12/06/08 10:33 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Transmission has no fluid in it nor does converter.
Re: fluid for 904 transmission [Re: derekeh] #162985
12/06/08 11:35 AM
12/06/08 11:35 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Type F with 1 qt of 30w non-detergent motor oil.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: fluid for 904 transmission [Re: Evil Spirit] #162986
12/06/08 12:25 PM
12/06/08 12:25 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Type F with 1 qt of 30w don-detergent motor oil.
Wh6y nondetergent??? As you know ATF is a very high detergent lubricant.
Re: fluid for 904 transmission [Re: MoparforLife] #162987
12/06/08 12:44 PM
12/06/08 12:44 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I was told that non detergent oil has less issues with foaming. I'm not a chemist, so I'm just going on told by a guy that heard from a guy that knew a guy... Besides, if it's good enough for a Briggs and Stratton...
Re: fluid for 904 transmission [Re: Evil Spirit] #162988
12/06/08 01:14 PM
12/06/08 01:14 PM
Upper Midwest
Upper Midwest
Re: fluid for 904 transmission [Re: MoparforLife] #162989
12/06/08 01:34 PM
12/06/08 01:34 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
We started using Type F in stock trans' because it gave a firmer shift feel after fluid changes than Dextron did, and it carried over into our performance builds. We started using a qt of 30w in them to improve lubrication - non detergent for (perceived) less foaming. I've used shift kits for A500's that suggested adding the motor oil. Use what you wish - this is what I use and why. As I said, I'm not a chemist. As to the "Briggs" comment, it was to amuse, not confuse. It was free and worth every penny. Maybe 2
Re: fluid for 904 transmission [Re: Evil Spirit] #162990
12/06/08 01:57 PM
12/06/08 01:57 PM
Upper Midwest
Upper Midwest
I am not trying to start a feud. I was just wondering the reasoning for the non detergent. I use Type F for the non foaming reason along with seemingly firmer shifting. 3 seasons ago I replaced the transmission in the drag car that a friend of mine and I built in 1992 for the car. It still worked flawlessly but I had another sitting on the garage floor that I had rebuilt for replacement so decided to put it in along with a different converter. The transmission that I took out had the fluid changed a couple of times in the interval with countless passes on it. There was vertually no crap in the pan. Note these rebuilds were both done using over the counter OEM type 727 kits and using Type F fluid. IMO use what works for you.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: fluid for 904 transmission [Re: MoparforLife] #162991
12/06/08 02:10 PM
12/06/08 02:10 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
We have several 904's that we push 600+ hp through, and the extra lube can't hurt. Some of them are running drilled driving shells that throw a lot of fluid around, so we use the n/d oil. Stock planetaries put a lot of load on the bushings, and it doesn't seem to be cost effective to roller bearing the trans when there is little performance gain and the oil seems to do the trick. to ya!
Re: fluid for 904 transmission [Re: Evil Spirit] #162992
12/06/08 02:23 PM
12/06/08 02:23 PM
Upper Midwest
Upper Midwest
And one for you -
