69 satellite-core support change-help #162963
12/06/08 02:10 AM
12/06/08 02:10 AM
st.charles,mo.
dodgem1 Offline OP
dodgem1  Offline OP
st.charles,mo.
hi,has anyone ever changed a c-s in a 69 b body,does it bolt in or is it welded too,is it tough,my car has a 44 in it now,the last guy butchard it up,would like to install a new 26 inch c-s,thanksin advance
Re: 69 satellite-core support change-help [Re: dodgem1] #162964
12/06/08 02:14 AM
12/06/08 02:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Core Support is welded..
Re: 69 satellite-core support change-help [Re: 1_WILD_RT] #162965
12/06/08 02:30 AM
12/06/08 02:30 AM
st.charles,mo.
dodgem1 Offline OP
dodgem1  Offline OP
st.charles,mo.
yes but has anyone ever changed one,was it tough
Re: 69 satellite-core support change-help [Re: dodgem1] #162966
12/06/08 03:12 AM
12/06/08 03:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I changed both side plates on my Coronet, (Was 22" now 26") it depends on your abilities, it's not overly hard but you need to be able to cut, measure, weld & finish..Did mine in about four hours, if I didn't tell you it's been done you wouldn't be able to tell unless you know how to read the 68 fendertag...
Re: 69 satellite-core support change-help [Re: 1_WILD_RT] #162967
12/06/08 03:52 AM
12/06/08 03:52 AM
st.charles,mo.
dodgem1 Offline OP
dodgem1  Offline OP
st.charles,mo.
thanks for the info
