Re: Reverse rotation 360 [Re: OUTLAWD] #1629616
06/07/14 05:10 PM
06/07/14 05:10 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I would think the oil pump would be reverse rotation also.
Re: Reverse rotation 360 [Re: dezduster] #1629617
06/07/14 06:44 PM
06/07/14 06:44 PM
Iowa
coronetville Offline
Iowa
go really fast in reverse
Re: Reverse rotation 360 [Re: BJS racing] #1629618
06/07/14 07:02 PM
06/07/14 07:02 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
hell I would run it as a reverse rotation! It will really freak people out when you nail the throttle and the right front picks up instead of the left front. But that is just me!
Transmission wouldn't work either...
If you can't handle the truth, you're living a lie.......
Re: Reverse rotation 360 [Re: Big Squeeze] #1629619
06/07/14 11:38 PM
06/07/14 11:38 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Ya it would not pump fluid and the converter might not work as well
Re: Reverse rotation 360 [Re: littleVAL] #1629620
06/08/14 12:05 AM
06/08/14 12:05 AM
West Palm Beach, Florida
Copper Dart Offline OP
Not that it helps much but if you look at the two cam pictures, you should notice that they are cut to keep the dizzy ( and oil pump ) spinning clockwise.
Doesn't matter at this point, I chickend out and had to buy another short block just to make good on my word. At this point, it's like I'm/we're doing all the work for free for a friend because my customer isn't the one who made the mistake.
The local ( run of the mill) machinist that sold me the engine (last year for a project that fell thru) is the one who should get his [Edited by Moparts - Family Friendly Site - Keep it clean] kicked! He's no where to be found and good riddins.
I will do what I can/have to to finish the job.
I'm sure someone out there could use this fresh reverse rotation 30 over 360 with a nice purple shaft cam, it should make for a nice engine just backwards
I might find out that all I need to do is to replace crank and cam, the rest is pretty nice.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629621
06/08/14 03:46 AM
06/08/14 03:46 AM
Q
Quicktree Offline
Quicktree  Offline
Q
that sucks Rick, put that thing in the boat section of Craigslist and sell it
Re: Reverse rotation 360 [Re: Quicktree] #1629622
06/08/14 11:46 AM
06/08/14 11:46 AM
As said I'd see if you could flip it on a Mopar boat site & get some or all of your equity back. Smokey Yunick made one of his engines reverse rotation so it would torque over to the left which would help the stock car turn left easier. Me I'd wanna run it . IF the knurling does push oil out I would polish it down to minimize that & I think all the other issues could be easily dealt with ex what about the starter as it needs to be cranked CCW. I wourked on an inboard 318 once & that was what stuck out in my recollections. That and it had a strange firing order 2-1-8-4-3-6-5-7 iirc
Re: Reverse rotation 360 [Re: RapidRobert] #1629623
06/08/14 05:35 PM
06/08/14 05:35 PM
Robert,
I was thinking the same for the knurling too.
P.S. Check you firing order
It's the same as any other LA, you just started with 2 instead of 1
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629624
06/08/14 06:22 PM
06/08/14 06:22 PM
I was just thinking & trying to remember if the FO I said was what it really was as it was 15 yrs ago but it jogged my memory & on the starter it had a special bellhousing & the starter bolted in from the rear & that's how they got around the rotation issue
Re: Reverse rotation 360 [Re: RapidRobert] #1629625
06/08/14 06:49 PM
06/08/14 06:49 PM
I wondered about that thinking... reverse polarity starter?
Thanks for the answer!
We will have to jog you every now and then
Mom.
Ricky Valdes
