9 1/4 Factory clutch pack setting?
#1629563
06/06/14 05:14 PM
06/06/14 05:14 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Factory 9 /14 rear out of a Dakota. I believe the clutch pack were installed improperly. Do the clutches, which are concaved or convexed depending on how u look at it, do they go against the gear with the small end pointed towards it? Or is it the other way aroung? Hope I explained this correctly. Matt
Re: 9 1/4 Factory clutch pack setting?
[Re: VernMotor]
#1629566
06/06/14 07:17 PM
06/06/14 07:17 PM
MattW
Ontario Canada
I hope I can explain it right. The center inside that is the highest if you would set them flat would go to the gears. It is called a belleville . spring. Ma-mopar don't even show a good pic or tell you how it go's LOL Hope this helps.
So if its a dinner plate the side that would be touching the table would be touching the gear. If this is right then one side was the opposite. Thank you sir ![](/ubbthreads/images/graemlins/thumbs.gif) Matt
[Re: MattW]
#1629567
06/06/14 07:58 PM
06/06/14 07:58 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Yes and both should be the same.
[Re: VernMotor]
#1629568
06/06/14 08:13 PM
06/06/14 08:13 PM
MattW
Ontario Canada
The rear must of been assembled Friday. lol THX
