Tips for installing clutch fork? #1629514
06/06/14 11:33 AM
06/06/14 11:33 AM
Arizona
68CoronetRT Offline OP
Arizona
I have an 11" bell housing/clutch assembly.
The clutch fork I installed during assembly turned out to be the wrong one. It was too long and didn't line up with the linkage.
I was able to remove it but now the correct fork does not want to go in.
Its very close but the pads that contact the throw out bearing on about 1/16" of an inch from clearing enough for the fork to slip onto the pivot bracket.
I cannot seem to apply enough force to the throw out bearing to make it clear.
One question I have is concerning the pivot bracket. Is it at 90 degrees to the mounting surface? Thought maybe it got bent slightly when removing the other fork.
I will be attempting to install the clutch fork when I get home from work to day. So if I don't reply right away that is why.
Re: Tips for installing clutch fork? [Re: 68CoronetRT] #1629515
06/06/14 12:11 PM
06/06/14 12:11 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
It's easiest to do with the transmission out. You're risking snapping a retainer clip at the T.O. bearing by forcing it in. I have an unused pivot. It's a beefy piece and wouldn't bend very easy.
Re: Tips for installing clutch fork? [Re: Pynzo] #1629516
06/06/14 06:03 PM
06/06/14 06:03 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Another Pic.
Re: Tips for installing clutch fork? [Re: Pynzo] #1629517
06/07/14 12:48 PM
06/07/14 12:48 PM
Arizona
Arizona
I was able to get the fork installed without removing the transmission.
It was a matter of getting everything aligned just right.
Thanks for the help.
Re: Tips for installing clutch fork? [Re: 68CoronetRT] #1629518
06/07/14 01:21 PM
06/07/14 01:21 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Awesome! What linkage are you using? I switched to the truck style years ago and haven't had to replace anything since then. The plastic isolator kept wearing out throwing off my adjustment. Think I went through 3 of them.
