Bad ignition switch or starter relay ? #1629367
06/05/14 08:34 PM
06/05/14 08:34 PM
Buckle of corn belt ,c. lll.
420SIX Offline OP
420SIX  Offline OP
69 B-body....12.5 v going to relay, tried jumping relay terminals & still not engaging starter. Seems like relay to me ?? But could it be the ignition switch ?
Re: Bad ignition switch or starter relay ? [Re: 420SIX] #1629368
06/05/14 08:51 PM
06/05/14 08:51 PM
You jumped the large "batt" terminal on the starter relay to the brown wire "sol" terminal next to it & it did not crank? At the starter relay the "grn" terminal needs to be grounded in park/neutral and the yellow wire to the "ign" terminal needs to be hot when the key is held to "start". Holler back
Re: Bad ignition switch or starter relay ? [Re: 420SIX] #1629369
06/05/14 09:02 PM
06/05/14 09:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Crank the key and wiggle the big plugs under the steering column. Could be there.
Re: Bad ignition switch or starter relay ? [Re: RapidRobert] #1629370
06/05/14 09:07 PM
06/05/14 09:07 PM
420SIX Offline OP
420SIX  Offline OP
Yes ...Jumped bat terminal to large brown terminal under it...nothing....4spd car so only yellow wire to single spade terminal
Re: Bad ignition switch or starter relay ? [Re: 420SIX] #1629371
06/05/14 09:32 PM
06/05/14 09:32 PM
With a screwdriver carefully jump the large/small terminal(s) at the starter. (1) either the starter is bad (fairly common) or the starter case has no continuity to the trans mounting face (ground) & that is rare as there is alot of surface area. (3) Bad terminal (open) on either end of the brown wire from SR down to starter or same deal on the large wire from SR "Batt" terminal down to starter.
Re: Bad ignition switch or starter relay ? [Re: 420SIX] #1629372
06/05/14 10:00 PM
06/05/14 10:00 PM
NC
1970A66 Offline
1970A66  Offline
NC
Just to clarify......when you jumpered these 2 terminals your starter motor should have turned over.
Re: Bad ignition switch or starter relay ? [Re: 1970A66] #1629373
06/05/14 10:13 PM
06/05/14 10:13 PM
420SIX Offline OP
420SIX  Offline OP
Jumped the 2 terminals on relay....starter does not engage....bad starter solenoid ?
Re: Bad ignition switch or starter relay ? [Re: 420SIX] #1629374
06/05/14 10:15 PM
06/05/14 10:15 PM
jump the 2 terminals on the starter itself (you should be seein some sparks)
Re: Bad ignition switch or starter relay ? [Re: RapidRobert] #1629375
06/05/14 10:48 PM
06/05/14 10:48 PM
420SIX Offline OP
420SIX  Offline OP
Loose terminal on starter...case closed...thanks for the help guys....
