22" Fan Shroud Woes #1629350
06/05/14 07:28 PM
06/05/14 07:28 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I went to install the radiator in my 68 Barracuda today and when I went to bolt on the shroud, I saw it won't fit my radiator. My radiator is 22" part # 2898028 (1968 A body 318/340) and was beautifully restored by Glen Ray. My shroud is an NOS part, # 2785614 (1968-69 A body 22")
The shroud mounts are a good 1/4" short of the radiator mounts (top to bottom - side to side fit is OK). Anyone else have this problem? Will another shroud fit or what did you do to correct the problem?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 22" Fan Shroud Woes [Re: Erik] #1629351
06/05/14 07:54 PM
06/05/14 07:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Call glen ray
Re: 22" Fan Shroud Woes [Re: autoxcuda] #1629352
06/05/14 09:11 PM
06/05/14 09:11 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Instead of telling us talk to Bob at Glen-Ray the best service you'll ever find.
Re: 22" Fan Shroud Woes [Re: RJS] #1629353
06/05/14 11:13 PM
06/05/14 11:13 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You sure you have the shroud on the correct way and not upside down? Also, you sure it is NOS and not one of the two repops that were done over the last 20 years? The first repops were junk and would explode and ruin the radiator after a few months (sometimes weeks)! The later repops were better but still not perfect. Both repops have the 614 number on them.
JB Rhinehart, Realist
A-Body's RULE!
Re: 22" Fan Shroud Woes [Re: Rhinodart] #1629354
06/06/14 12:33 AM
06/06/14 12:33 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
As mentioned above by Rhinodart, there were repops that had fitment problems. They had the Chrysler logo and part# on them so would be difficult to tell from NOS. The link below has info and pics.
http://www.forabodiesonly.com/mopar/showthread.php?t=54223
Here is quote from one of the posts;
"So I was communicating via email with Todd at Hoffmans Winners Circle recently and I mentioned the problem I had with a "614" fan shroud not fitting right and warping into the fan after a very short time. I know others have complained about this. (I believe Hoffmans is the primary wholesaler of these repro shrouds to all the other retailers).
... It arrived today from a plastics manufacturer in Ohio. I immediately compared it to the first one I bought. The cast in part numbers are identical. The Chrysler logo has now been ground off. There are significant dimensional differences in mounting hole spacing (now correct) and even the diameter of the fan opening - from 19" to now 20". When you lay them over the top of each other, the older one looks like a shrunken down version of the current one".
Re: 22" Fan Shroud Woes [Re: moparfan53] #1629355
06/06/14 12:48 AM
06/06/14 12:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If anyone here is curious about fan shrouds simply ask the vendor how they were made. Original shrouds were ALL made using the plastic injection molding process which involves running a large molding machine and metal injection mold tooling, the parts are made of thermoplastic polyethylene resin.
All of the reproductions I've seen were CAST in a soft silicone mold and were made from poured liquid urethane casting resin which is poured into the soft mold and left while it cures solid.
The reproductions look virtually identical to an original but will usually have some small dimensional shrinkage and will have ENTIRELY different material properties in terms of heat resistance, warpage, etc.
Re: 22" Fan Shroud Woes [Re: moparfan53] #1629356
06/06/14 11:05 AM
06/06/14 11:05 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I didn't realize the repops had the part number. And mine does have the Chrysler logo ground off so I would have to conclude it's one of the crappy repops. Are the current repops any better?
I am very impressed with Glen-Ray and they did an EXCELLENT job. The shroud fit is really not their issue.
Re: 22" Fan Shroud Woes [Re: Erik] #1629357
06/06/14 06:59 PM
06/06/14 06:59 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
If anybody's interested, here's data on a factory 614 shroud from my 69 Barracuda.
The fan opening diameter is 19-11/16" side/side, 20-5/16" up/down, so the factory one has sagged a bit.
The fan opening is off center of the radiator about 5/8" to the passenger side. That is, it is 1-1/4" off the left side of the radiator, 0" off the right side.
Mounting hole pattern is 21-11/16" side/side, 13-1/4" up/down.
Here's a photo of the part number, unseen because it is located on the radiator side of the shroud, upper driver side. Color is charcoal gray, almost black, almost flat with very little shine.
Re: 22" Fan Shroud Woes [Re: Erik] #1629358
06/06/14 07:32 PM
06/06/14 07:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1st run or 2 of the shrouds did contain the part # and pentastar.
last ones have nothing cast into them, and are molded more of a grey color than black.
I haven't heard of any issues with the latest ones , but if u have a problem shroud contact the co. you bought it from ( if you know ) or contact Todd Hoffman and he will get you the latest version avail at no charge
Re: 22" Fan Shroud Woes [Re: gtx6970] #1629359
06/07/14 05:51 PM
06/07/14 05:51 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Just got mine from Mancini Yesterday. haven't installed as of yet but it looks as if the studs on the radiator line up with the holds on the shroud.
Installed my shroud last Sunday. Had to grind a little to clear the lower rad hose. Fits just great. I have an original A body shroud that has the part number but no pentastar. i'll check the should for my GTS to see what markings it has.
Re: 22" Fan Shroud Woes [Re: dart4forte] #1629360
06/10/14 02:12 PM
06/10/14 02:12 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
So after digging through years of receipts, I found that I ordered it from Year One back in 2009. So I called them to send it back and get a replacement and they will do it no problem!
Re: 22" Fan Shroud Woes [Re: Erik] #1629361
06/10/14 02:24 PM
06/10/14 02:24 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Another reason I don't rule out buying from Year One.
They also have a very good (possibly lifetime)return policy on unused parts as long as you have the receipt.
Re: 22" Fan Shroud Woes [Re: LimeliteAero] #1629362
06/20/14 11:17 AM
06/20/14 11:17 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Year One's replacement shroud arrived yesterday. Fit perfectly. I'll have new pics of the 'cuda's progress this weekend.
Re: 22" Fan Shroud Woes [Re: Erik] #1629363
06/20/14 12:02 PM
06/20/14 12:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Heat warpage, sagging, and melting would be the concerns with them. I have no doubt that the reproductions fit. Report back after driving around in the heat this summer and let us know how they hold up.
Re: 22" Fan Shroud Woes [Re: ScottSmith_Harms] #1629364
06/20/14 12:42 PM
06/20/14 12:42 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You think that's bad, try finding a fan shroud for a '68 Barracuda with a 22" radiator and a 5.9 Magnum with the serpentine belt. The top inlet is on the driver's side the bottom is on the passenger side the "small" 5 blade fan is 20" in circumference. They also make a fan with like 9 blades that made so much noise that the car sounded like it could lift off the ground at any moment, but boy did that thing move some air! Just too noisy though.
Supposedly a 1974 and up small block with a 22" radiator shroud will work, but I've yet to see one offered anywhere new or used that would fit.
I'm going to have make my own out of 18 gauge steel, bend it without a pan break and weld it up. I may just make a template out of some kind of card board and bring it to a friend of a friend who has all that sheet metal forming gear.
I'll seal the places it contacts the radiator with that high density foam tape with the sticky stuff on one side.
I'll also seal the A/C condenser to the front of the radiator so all the air has to go through both of them like I did on my 1970.
