Best heads for boosted smallblock? #1628987
06/04/14 11:47 PM
06/04/14 11:47 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I have a couple posts going on my cylinder head problem. If I do go with different heads what do you guys feel are the best heads for a 408 59* block boosted small block?
Re: Best heads for boosted smallblock? [Re: 80arrow] #1628988
06/05/14 12:05 AM
06/05/14 12:05 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
How fast are you looking to go and with what budget. Simple good old dependable Edelbrock heads are easily flowing 300-310 plus cfm with porting. No leaks, no issues, and easy to find rocker and good intake manifolds.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best heads for boosted smallblock? [Re: pittsburghracer] #1628989
06/05/14 12:12 AM
06/05/14 12:12 AM
Earth
Rob C Offline
Rob C  Offline
Earth
LOL! Hard to argue that one!
Re: Best heads for boosted smallblock? [Re: Rob C] #1628990
06/05/14 12:40 AM
06/05/14 12:40 AM
8
80arrow Offline OP
80arrow  Offline OP
I'm running a 360-1 right now. They do leak so that's not a good point. They flow 340. I was thinking about mopar "w" series heads. I want to go fairly fast I guess, lol.
Re: Best heads for boosted smallblock? [Re: 80arrow] #1628991
06/05/14 01:17 AM
06/05/14 01:17 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Go with a 48* w9 head and run a offset rocker like you have with the Indy. Then If you grow again you can get matching block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Best heads for boosted smallblock? [Re: 1967dartgt] #1628992
06/05/14 01:22 AM
06/05/14 01:22 AM
Arizona
Chris'sBarracuda Offline
Arizona
Things like This is why LS formats are so popular..
Chris
Re: Best heads for boosted smallblock? [Re: pittsburghracer] #1628993
06/05/14 01:28 AM
06/05/14 01:28 AM
Az
Crizila Offline
Crizila  Offline
Az
what I did.
Fastest 300
Re: Best heads for boosted smallblock? [Re: Crizila] #1628994
06/05/14 01:29 AM
06/05/14 01:29 AM
Az
Crizila Offline
Crizila  Offline
Az
intake port
Fastest 300
Re: Best heads for boosted smallblock? [Re: Crizila] #1628995
06/05/14 11:39 AM
06/05/14 11:39 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Best? That's extremely subjective... What are your goals? I run Eddy RPMs, but I'd go to W9's if I had the coin.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Best heads for boosted smallblock? [Re: 80arrow] #1628996
06/05/14 12:11 PM
06/05/14 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have the 360-1 but someone went too far with the
ports.. thats not the fault of the heads... they would
be my choice again but less porting... a standard CNC
port job would be it.. your running boost, if you want
more, just turn it up... that way all your parts will
work.. going to a W-9 will cost you big time.. every
thing from the head, rockers, lifters, pushrods, intake
valley, intake and custom headers... thats gonna cost.. its
not even cheap if you build most of the stuff yourself....
good luck with it
Re: Best heads for boosted smallblock? [Re: 80arrow] #1628997
06/05/14 04:46 PM
06/05/14 04:46 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Keep in mind that the biggest thing with boost or the sauce, is that what goes in must come out.
I would think exhaust flow numbers would be more important.
Matt
Re: Best heads for boosted smallblock? [Re: MattW] #1628998
06/05/14 04:57 PM
06/05/14 04:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Matt
Thats very very true... its easier to put more pressure
to the intake side but it still has to get out.. depending
on what style of pressure it is(turbo or blower) they
dont need the collector.. get it out as fast as possible
Re: Best heads for boosted smallblock? [Re: MR_P_BODY] #1628999
06/05/14 07:40 PM
06/05/14 07:40 PM
8
80arrow Offline OP
80arrow  Offline OP
Its a procharged set-up. I'm leaning towards another set of Indy's at the moment, but that could change.
Re: Best heads for boosted smallblock? [Re: 80arrow] #1629000
06/06/14 09:32 AM
06/06/14 09:32 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I know INDY had a great exhaust on the first run of CNC heads. They flowed 245 and up.
I THINK they changed it due to them breaking into the water jacket.
IMO INDY has a good design but a questionable product. IF you going to purchase a set, get them through a dealer have them checked out and I mean check everything.
Matt
Re: Best heads for boosted smallblock? [Re: MattW] #1629001
06/06/14 01:30 PM
06/06/14 01:30 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Stay away from the 245 heads, the 230 seem to have less problems.
Re: Best heads for boosted smallblock? [Re: 1967dartgt] #1629002
06/06/14 07:56 PM
06/06/14 07:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Figure out how much power you want to make and how much RPM you want to turn.
My Stock ported iron '308 heads with a sub .500" lift cam made ~725hp at only 240~250cfm flow.
The boost will make power on just about anything... no need to get carried away on the heads.
I just got a set of eddy for mine (to replace the cracked iron heads). They flow 290~300cfm with the MCH CNC port job. That is more then enough for the Chevy guys to make over 1000hp on a 80mm turbo. So no reason why a mopar can't do it either.
How much power do you want to make? How big of a blower/turbo? How much RPM? How much CID?
Same questions for a N/A motor still apply for boost.
Re: Best heads for boosted smallblock? [Re: dizuster] #1629003
06/06/14 08:25 PM
06/06/14 08:25 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Home ported Eddy heads for me...
Re: Best heads for boosted smallblock? [Re: dizuster] #1629004
06/06/14 08:54 PM
06/06/14 08:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think he has far exceeded that already
Re: Best heads for boosted smallblock? [Re: Quicktree] #1629005
06/06/14 11:49 PM
06/06/14 11:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Not saying that he doesn't can't make more...just making a point that flow isn't as important on a boosted car like n/a
Re: Best heads for boosted smallblock? [Re: dizuster] #1629006
06/07/14 12:07 AM
06/07/14 12:07 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
But with more flow you can make the same power with less boost or more power with the same boost.
Kevin
