High Performance street pads for 73+ Slider calipers?
#1628935
06/04/14 10:55 PM
06/04/14 10:55 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
My Duster currently has an 11.75 Slider disk setup in the front and 10x2.5" stock 74 drums in the rear, 15/16" master cylinder. Calipers are '80 Volare phenolic piston calipers with the 2.75" bore.
When I first did the conversion, it had some not great shape 10.87" rotors on the front and some semi-metallic pads. Didn't stop all that great...
I upgraded to the 11.75" brakes last year and threw on a new set of Wagner Thermoquiet pads. I am totally unable to lock the 225/60-15 BFG G-force sport tires on the front. It's adequate for tooling around town, and if you do a couple very hard stops, they start to work a bit, but they are absolutely nothing like the similarly sized brakes on my '04 Colorado or '12 Cruze which are phenomenal.
The brakes are fully bled with fresh synthetic Dot3/Dot4 when I put on the new master cylinder. The car has an adjustable prop valve in the rear line, and the pressure is dropped nearly all the way. It's not so hard to lock the rear, complete with the 20 year old shoes and likely original chrysler drums...I can get a screech out of the rears on almost any stop.
This is what makes me think it's the pad mu (friction coefficient)...I have driven 1000 miles since the brakes were installed, and I can still make out the cross-hatch on the brake plates.
Is there a set of brake pads that is street friendly (don't need to warm up forever), but have a high friction coefficient and hopefully won't squeal too much? I haven't seen much of a selection.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: High Performance street pads for 73+ Slider calipers?
[Re: PHJ426]
#1628940
06/07/14 11:38 AM
06/07/14 11:38 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
www.firmfeel. com
Has a nice set of pads and shoes give Dick a call
I've had good luck with these as well
[Re: ahy]
#1628942
06/07/14 12:37 PM
06/07/14 12:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My favorite street combo on an A body is nothing fancy. 11.75" rotors and 11" drums with organic pads and shoes. I used the combo valve out of a cop spec M body and a normal A body non-power disc brake spec M/C. Nice balanced stopping with long life.
[Re: BigBlockMopar]
#1628944
06/07/14 10:19 PM
06/07/14 10:19 PM
goldduster318
Lake Orion, MI
I think you guys were on to something with the cold bite. The current pads have little to none. My calipers, as mentioned earlier are 80 Volare Phenolics. They are the 2.75" piston. Slider type of course. Based on what you guys said...and what are on my other cars, I ordered a set of Bendix CQ NAO/Ceramic Pads. For what they cost...worth a shot. http://www.amazon.com/Bendix-D84-Ceramic-Brake-Pad/dp/B000C2LONI
[Re: goldduster318]
#1628945
06/26/14 01:37 AM
06/26/14 01:37 AM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
firm feel pads !! 11.75 rotors (napa )pin calipers 71 charger) 71 T A metering hold off valve from the ram man !!! 71 master cly 11 inch drums out back I put new wheel cly out back 3 years ago shoes are 15 years old !!! dual diaphragm power booster NAPA !! car has awe sum brakes !!! just as good as my 2007 magnum !!!
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
