Dash paint #1628875
06/04/14 08:19 PM
06/04/14 08:19 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Im about to repaint the dash on my 73 cuda. Is there anybody that makes something in a spray can that is close to original? I tried semi gloss black and satin black but they both look too shiny.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Dash paint [Re: 73cuda340] #1628876
06/05/14 07:30 PM
06/05/14 07:30 PM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Dash paint [Re: Erik] #1628877
06/05/14 10:03 PM
06/05/14 10:03 PM
clarks summit pa
clarks summit pa
ok thanks. What did you end up using for you dash? Any pictures? Thanks
Re: Dash paint [Re: 73cuda340] #1628878
06/06/14 08:45 AM
06/06/14 08:45 AM
SE Pa.
LimeliteAero Offline
SE Pa.
I didn't take the time to read the attached link but whatever you do, Do NOT use any paint with any degree of gloss! DAMHIK!
I know there are threads you could do a search for on Moparts to find a good spray bomb paint to use on the dash.
Re: Dash paint [Re: LimeliteAero] #1628879
06/06/14 09:21 AM
06/06/14 09:21 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Rustoleum makes a black textured paint that will get you extremly close,, otherwise it's mix and spray with a gun
which ever one you use spray it on wet and let it flow out
Re: Dash paint [Re: gtx6970] #1628880
06/10/14 08:48 PM
06/10/14 08:48 PM
clarks summit pa
clarks summit pa
I tried the rustoleum textured black paint and it looks great. Thanks
Re: Dash paint [Re: 73cuda340] #1628881
06/10/14 11:25 PM
06/10/14 11:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's that Rustoleum stuff called? Can you post a pic of the can. The only "textured" stuff I can find is either "wrinkle" or "hammered" and neither of those is even close.
Re: Dash paint [Re: Stanton] #1628882
06/10/14 11:47 PM
06/10/14 11:47 PM
clarks summit pa
clarks summit pa
Its just called rustoleum textured black. I got it at Walmart.
Re: Dash paint [Re: 73cuda340] #1628883
06/11/14 10:02 AM
06/11/14 10:02 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
How about a pic so we can see if it looks like the original finish or not? Something up close showing the texture.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Dash paint [Re: MOPARMIKE69] #1628884
06/11/14 07:58 PM
06/11/14 07:58 PM
clarks summit pa
clarks summit pa
I would have posted one but my camera is broke. Ill try to borrow one so I can put some pictures up.
Re: Dash paint [Re: 73cuda340] #1628885
06/11/14 09:38 PM
06/11/14 09:38 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
I've tried the Rustoleum paint also and I like it! Here's some pics of a test piece and my original ash tray next to it. The ash tray on my 71 has the texture molded into the plastic (in 1971) so I wanted to see how close the rest or the dash frame would be using this paint as a cheaper alternative. It looks very nice and matches the texture very close.
Re: Dash paint [Re: EL5 71] #1628886
06/11/14 09:39 PM
06/11/14 09:39 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
2
Re: Dash paint [Re: EL5 71] #1628887
06/11/14 09:41 PM
06/11/14 09:41 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
3
Re: Dash paint [Re: EL5 71] #1628888
06/11/14 09:45 PM
06/11/14 09:45 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Re: Dash paint [Re: EL5 71] #1628889
06/11/14 09:47 PM
06/11/14 09:47 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Last one for now. I know, hurry up and paint the dash frame. lol I haven't finished soda blasting it yet but I will post some pics when it's done. Hopefully it comes out good like the sample piece. Eddie
Re: Dash paint [Re: EL5 71] #1628890
06/11/14 09:52 PM
06/11/14 09:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm guessing if the dash was painted and the ashtray molded plastic, that the latch wouldn't have been perfect anyway.
I'm thinking of having my dash dipped but I'm wondering what the vin plate is made of and coated with. Don't want it damaged in the process but don't want to unnecessarily shell out for new rivets either.
Re: Dash paint [Re: Stanton] #1628891
06/11/14 10:37 PM
06/11/14 10:37 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I ground off my rivets from the underside of the dash and save the heads and removed the vin. My dash was sand blaster and powder coated. The rivets were then epoxied from underneath.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Dash paint [Re: FJR doc] #1628892
06/12/14 01:05 PM
06/12/14 01:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only issue I see here is that this is "cheap" paint being applied to one of the most difficult pieces to remove and redo if it gets damaged in any way. If there is one place on the car you want to use a high quality, durable paint, the dash is it. I'm sitting on the fence here!
Re: Dash paint [Re: Stanton] #1628893
06/12/14 02:56 PM
06/12/14 02:56 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used the Rustoleum textured paint on my steering column with really good results. However, I couldn't get a consistent finish that pleased me on my dash frame. I ended up having it blasted and getting it powder coated at a very reasonable price.
Kevin
