Page 3 of 4 1 2 3 4
Re: reading these plugs [Re: Monte_Smith] #1628696
06/05/14 08:26 PM
06/05/14 08:26 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I guess I'm just old - but I still pull the plugs - even if I'm going over the logs to see what the wideband said during a pass. I keep killing O2 sensors and have to more or less "figure out" what each different sensor thinks before I can make changes based upon the logs. So I end up going off the plugs like always most of the time.
I'm pretty sure the raw fuel while on the 2-step is what destroys them. I can drive around and make WOT passes all I want, but 2 or 3 launches using the 2-step and another sensor is junk.
Re: reading these plugs [Re: Quicktree] #1628697
06/05/14 08:30 PM
06/05/14 08:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The wide band is going to possibly become a new found tuning friend and answer some major questions for ya............
the wide band sucks for racing imo, I bought a complete FAST set up for my E85. set it exactly what was called for. even put the car on a chassis dyno and let him hook his up. he told me it was perfect. got to the track and it was .15 slower, jetted down 2 sizes and picked right back up. so I am not sold on wide band for racing, thats why I asked for some kind of credible info from people who have tuned with one in relationship to racing and being consistent. the last time this subject came up
Tony... a wide band doent tell you max MPH.. you have
to play to find that... once you find that point you
have a reference point to get back to.. thats why
I use my AFR for mid/cruise only... but once I get
the best points then I write down those numbers for
thos conditions(temp, load,timing, fuel).. change
ANY ONE POINT then I have to find new numbers
Re: reading these plugs [Re: Quicktree] #1628698
06/05/14 09:03 PM
06/05/14 09:03 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I hear all that, but I will have something more to look at. Might be ok for idle and cruise work, but I was always taught MPH is the most important thing to look at when jetting - and I can only do that at the track. At any rate, just finished welding in the 02 bung and it's an hour past my nap time, so I'm done for the day.
I hope you have a long extension or pipes on that thing or you wont get good readings.
I run 12" bolt on collector extensions. Tip of sensor sits in the air stream. Bung was part of the kit. I just welded it on.
Fastest 300
Re: reading these plugs [Re: Crizila] #1628699
06/05/14 10:20 PM
06/05/14 10:20 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
What's your target AFR at WOT?
Re: reading these plugs [Re: Duner] #1628700
06/05/14 11:27 PM
06/05/14 11:27 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Hey Blaine, 11.5 would be nice - and safe . What's yours?
Fastest 300
Re: reading these plugs [Re: Crizila] #1628701
06/06/14 12:57 AM
06/06/14 12:57 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I was trying to keep it safe clear down there… and then I noticed that mine really didn't like it there. Mine - with the nice cold air/water intercooler - likes it at 12.2:1 and really doesn't seem to complain at 12.5:1. So that's what my range is. I try to keep it in between those as best I can… although it's really tough since mine eats O2 sensors so often. I go by the plugs - but watch the O2 if I'm making tuning changes. I just have to keep a new sensor around for the occasion.
Re: reading these plugs [Re: Quicktree] #1628702
06/06/14 01:10 AM
06/06/14 01:10 AM
SoCal
Brian Hafliger Offline
SoCal
X2!
Brian Hafliger
Re: reading these plugs [Re: Quicktree] #1628703
06/06/14 02:37 PM
06/06/14 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I am giving credible info and never said it`s an "end all" but it gets you real close then you fine tune from there. Once I installed mine and street tuned it when it surged I peeked at the w/b and saw it was rich on cruise so I worked that circuit then repeated till idle and cruise were good and verified that by plug reading. Then tuned wfo saw that it was lean and tuned from there and so on. But hey, we all have our own ways of doin things and some guys still say, "I`d rather be lucky than good" but not me.............I rather learn to be good and get BETTER...........
Re: reading these plugs [Re: Thumperdart] #1628704
06/06/14 06:31 PM
06/06/14 06:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you can't be serious, what you call racing and what real racing is are 2 totally different things
Re: reading these plugs [Re: Quicktree] #1628705
06/06/14 06:48 PM
06/06/14 06:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What does my sig et mean? That`s racing to me.............
Re: reading these plugs [Re: Duner] #1628706
06/06/14 06:59 PM
06/06/14 06:59 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Duner, I am suprised you are killing O2 sensors. I run mine with the brake and don't have any problems. I run mine a little richer to be on the safe side, if that makes a diff. I do plan on leaning it up a bit though next time.
Right now: 10.9 AFR
Future: 11.5
Re: reading these plugs [Re: TheOtherDodge] #1628707
06/06/14 08:08 PM
06/06/14 08:08 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Gathering all the info you can get your hands on is the best way to get the a/f right. Plug readings, wideband and/or narrow band, and some sort of data recording. Plugs get you in the ball park. wideband gets you what your a/f is, and narrowband tells you what a/f your engine "likes". Putting to much faith in a wideband can be very misleading... especially if you are chasing a number instead of listening to your engine... Different engine conditions(load/RPM) will require different ratios.
Re: reading these plugs [Re: TheOtherDodge] #1628708
06/06/14 10:09 PM
06/06/14 10:09 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Right now: 10.9 AFR
Future: 11.5
Mine picked up a ton by going a little bit leaner. Like 3 tenths and 3 mph worth of picked up! Of course what looked like rich on the dyno ended up being a full point leaner in high-gear on the track. The added load from trying to push a barn door thru the wind meant it wanted more fuel.
I am going to try an entirely different wideband setup…. I could have paid for an entirely new system with what I've already invested in just the sensors.
Re: reading these plugs [Re: Duner] #1628709
06/06/14 11:02 PM
06/06/14 11:02 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Right now: 10.9 AFR
Future: 11.5
Seems odd that it eats sensors. I'll ask a couple of stupid questions given your credentials .
Unleaded fuel?
Sensor is clocked somewhere between 9:30 and 2:30?
And just so I don't hi-jack the OP, the bung clocking is important because any liquid or condensation needs to be able to drain out of the sensor or it will go bye bye. The OP's looks like it might be pointing the wrong way once the header is installed but it could be just the angle of the photo.
Kevin
Re: reading these plugs [Re: Twostick] #1628710
06/06/14 11:12 PM
06/06/14 11:12 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Unleaded fuel?
Kevin
The sensor is clocked at about 1:30 (45° angle down) - but it does see some leaded fuel at the track. I fully realize that leaded fuel will shorten the life span - but I'm only getting 3 or 4 passes if I use the 2-step. Without the 2-step they seem to last however long I drive it until I DO use the 2-step…. whether it's 2 or 3 months or just a day.
I have credentials? Hahahaha
Re: reading these plugs [Re: Duner] #1628711
06/06/14 11:52 PM
06/06/14 11:52 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think the leaded fuel with the 2 step is your problem. I don't know if changing to a different brand will help much unless some types of sensors are more tolerant of lead than others.
Kevin
Re: reading these plugs [Re: Twostick] #1628712
06/06/14 11:55 PM
06/06/14 11:55 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
You are probably right.
Re: reading these plugs [Re: Duner] #1628713
06/07/14 01:55 AM
06/07/14 01:55 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
NTK sensors tollerate lead much better than the bosch sensors from what Ive been told. They are much more expensive though...
Re: reading these plugs [Re: Duner] #1628714
06/07/14 02:01 AM
06/07/14 02:01 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are you familiar with VP-101 unleaded? Sez good for turbo charged and compressions up to 12.1 w/iron and 13.1 w/alum heads.............been runnin it for a couple years now.
Re: reading these plugs [Re: Thumperdart] #1628715
06/07/14 02:07 AM
06/07/14 02:07 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I can get that at the pump - but I usually mix 110 leaded with my 92 octane premium.
My boosted compression ratio on my iron head 360 ends up being 21.4:1
(9.5:1 + 18.8 psi of boost)
Page 3 of 4 1 2 3 4
