Did I install my trunk seal wrong? 1969 GTX... #1628646
06/04/14 05:06 PM
06/04/14 05:06 PM
Somewhere near Palm Springs
ConvertiBee Offline OP
I either installed it wrong or got sold a bogus seal... which is it? My lid won't close now
[img]https://photos.google.com/search/_tra_/photo/AF1QipP622C0UgUgrRn9SDVmwoPXVW4gJ4A2UcAzWOit[/img]
'69 GTX 440 D21 A34 N96
'70 Coronet 383 'Vert
'71 Demon 340 SixPack 4-Speed
'72 Cuda 340 FE5
'74 Kawasaki Z1, and...
(12) Japanese Enduro's and SuperBikes from the 1970's! smile
Re: Did I install my trunk seal wrong? 1969 GTX... [Re: ConvertiBee] #1628647
06/04/14 05:19 PM
06/04/14 05:19 PM
iirc a guy had that problem on here last year & he raised the trunk lid adjustment so it did not crush it as much & let it set that way for awhile then readjusted it so it crushed it a bit more & let it sit that way for a spell then did a final readjustment down where he wanted it. Do you still have the old seal so you can compare thicknesses/shape dimentions?
Re: Did I install my trunk seal wrong? 1969 GTX... [Re: RapidRobert] #1628648
06/04/14 05:23 PM
06/04/14 05:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It will need to be flattened out as Robert said.
Re: Did I install my trunk seal wrong? 1969 GTX... [Re: stumpy] #1628649
06/04/14 05:36 PM
06/04/14 05:36 PM
Okay: Thank you... I just wanted to make sure I did'nt install it upside down or get the wrong type seal. There was'nt much left of my 45-year-old seal.
I will just give it time
'72 Cuda 340 FE5
