Set of plug wires #1628598
06/04/14 03:36 PM
06/04/14 03:36 PM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
I am looking for a set of plug wires already made up.Who sells them and what ones are the best.I have been using carbon fiber are great at first but don't seem to last one little sharp bend and they start to fail.
I need them for a 440.
Thanks in advance
Re: Set of plug wires [Re: 1967GTX440] #1628599
06/04/14 03:41 PM
06/04/14 03:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run nothing but Taylor Spiro pros.Already made.Mine have been on at least 15 years with headers and still work fine.My kids have been on 10 years same thing.Ill replace mine soon as they are looking tacky but are still pliable and dont leak.I even run them on our Harleys.Rocky
Chrysler Firepower
Re: Set of plug wires [Re: therocks] #1628600
06/04/14 04:03 PM
06/04/14 04:03 PM
Ontario,Canada
Ontario,Canada
Where can I purchase them
Re: Set of plug wires [Re: 1967GTX440] #1628601
06/04/14 06:07 PM
06/04/14 06:07 PM
Mount Airy, Maryland
scrag Offline
scrag  Offline
I have been using firecore wires and like them alot. They make stock and custom to order sets.
http://www.firecore50.com/
Re: Set of plug wires [Re: scrag] #1628602
06/04/14 07:13 PM
06/04/14 07:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Summit has the Taylors in stock.We run just the regular Spiro Pros.Mine are blue and the kid runs red ones.They also make them in 10 MM which is way over kill unless you are a serious racer.Rocky
Chrysler Firepower
Re: Set of plug wires [Re: therocks] #1628603
06/04/14 07:25 PM
06/04/14 07:25 PM
dogdays Offline
dogdays  Offline
The maker of Firecores is a board member (Rick Sparky Sunroof GTX) and people really seem to like his products. Since he thinks I dinged him last week, I will put in this good word for his stuff here.
Another thing, if you have a special need, like shorter or longer or different boots, it seems that he can accommodate without it becoming a big hassle. This can be a real advantage when you want to keep the engine compartment neat.
For example, I have a $500 pickup that needed wires to get it out of the back yard so I bought the least expensive set from Rockauto. I knew they would be cheap, but what I didn't expect was around 6" of extra length on each of the "custom fit" leads. It looks like a spaghetti factory under the hood.
Good Luck!
R.
Re: Set of plug wires [Re: 1967GTX440] #1628604
06/04/14 09:50 PM
06/04/14 09:50 PM
If your 440 has wires on it now you might measure their lengths so you can compare then to a potential purchase to get an exact match for a neat eng compartment tho I've shortened wires and recrimped the brass terminal back on with no issues & most wire strippers/crimpers have a notch or two for that function. AutoZone has a set with 90 deg boots Duralast #1601 for $15 and #1600 is straight boots. I'm sure you're looking for something better but I just wanted to toss that info in
Re: Set of plug wires [Re: RapidRobert] #1628605
06/04/14 10:38 PM
06/04/14 10:38 PM
South San Francisco, Ca
70sixpkrt Online content
70sixpkrt  Online Content
Re: Set of plug wires [Re: 70sixpkrt] #1628606
06/09/14 12:27 AM
06/09/14 12:27 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Thanks a ton, guys. Ron is our dealer up in Canada. He runs the Dodge Charger board, and mostly hangs out there. His number is on our website... www.customwiresets.com. We have sets that will already fit...right out of the box. Thanks, thanks Dog..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
