Re: Front end shake
[Re: RapidRobert]
#1628575
06/04/14 05:20 PM
06/04/14 05:20 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Replace the lower Poly bushings with factory style rubber 1s. The polys allow the lowers to move in and out a little.
I am truckless..
Re: Front end shake
[Re: RapidRobert]
#1628578
06/04/14 06:03 PM
06/04/14 06:03 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Ding ding ding we may have a winna I thought the descrip sounded different from anything that I had ever heard of regarding that type of deal
Trust me, it is a very unique shake that comes and goes every few seconds and only at that speed.. wish I had an extra set of wheels and tires to try out, that would be the first step..
Will possibly change out the lower bushings eventually. Just not ready to chase after it by changing out parts at this point..
Re: Front end shake
[Re: mopar_man]
#1628581
06/05/14 09:50 AM
06/05/14 09:50 AM
floridian
Lakeland FL
The tires could be in balance but still be out or round. balance is static , out of roundness is dynamic ..........or is it the other way around? Jeez, getting too old to figure it out any more lol . anyway try another set of tires on the front before you start throwing parts at it
This is actually what it feels like, out of round tires, but why only between 37 - 41 MPH?? I purchased the front tires out of a persons attic, they did not fit on the front of his Nova....
Rear wheels and tires will not fit up front, too wide.....
Re: Front end shake
[Re: floridian]
#1628583
06/05/14 06:33 PM
06/05/14 06:33 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
because That speed is the "Goldylocks zone" where the harmonic balance of the car and tire match up and then you have a vibration . Much like a drive shaft , lets say you have a very minor bend in the drive shaft , you won't feel the vibes until your in or near "the zone". Get tires and wheels and give it a try .
Re: Front end shake
[Re: Dcuda69]
#1628585
06/06/14 02:03 AM
06/06/14 02:03 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Out of round is pretty easy to check too.
Jack up the car and spin the wheels. Look at the runout on the tread surface. The bead area of the rim should be almost zero.
