1992 jeep 4.0 no start #162797
12/05/08 07:55 PM
12/05/08 07:55 PM
CENTRAL MINN
1965_PLYMOUTH Offline OP
CENTRAL MINN
I started a post on this jeep a few weeks ago, and am finally getting back to it. I put in a cam/crankshaft sensor because the old one read bad (over 17 ohms resistance), but it still has no spark. I was just driving the truck normal when it died. any ideas?
Re: 1992 jeep 4.0 no start [Re: 1965_PLYMOUTH] #162798
12/05/08 08:10 PM
12/05/08 08:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Check the resistor on the driver side fender,looks just like a ballast resistor.
Re: 1992 jeep 4.0 no start [Re: 62maxwgn] #162799
12/05/08 08:22 PM
12/05/08 08:22 PM
CENTRAL MINN
CENTRAL MINN
yep. looked at it and checked it. good / good. still no spark, but cranks good. thanks
Re: 1992 jeep 4.0 no start [Re: 62maxwgn] #162800
12/06/08 06:37 PM
12/06/08 06:37 PM
PA
70Duster Offline
70Duster  Offline
PA
That's in the fuel pump circuit on a '92 Jeep. If it was bad, it would not cause a no spark condition.
Check the coil.
Re: 1992 jeep 4.0 no start [Re: 70Duster] #162801
12/06/08 06:45 PM
12/06/08 06:45 PM
Wis., USA
Bob_Fromm Offline
Bob_Fromm  Offline
Wis., USA
Coil pickup in the distrib. is bad I have a 92 Laredo that had same problem.
Re: 1992 jeep 4.0 no start [Re: Bob_Fromm] #162802
12/09/08 09:44 PM
12/09/08 09:44 PM
CENTRAL MINN
CENTRAL MINN
coil tested good with ohmeter. still no spark. I had to change the distributor because the customer tried fixing this jeep himself and twisted the dist. cap screws off. maybe I bought a bad dist. on ebay. the guy said the motor ran that he pulled it out of. I suppose I should figure out how to test the distributor itself next. thanks.
Re: 1992 jeep 4.0 no start [Re: 1965_PLYMOUTH] #162803
12/10/08 12:26 AM
12/10/08 12:26 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
you would not need to replace the whole distributor again most likely; just the dist pick up plate/some call it a "hall effect plate" or cam sensor.
