440 Six Pack Stamped Steel Rockers #1627584
06/02/14 03:12 AM
06/02/14 03:12 AM
USA
rftroy Offline OP
rftroy  Offline OP
USA
How do you identify original 440 Six Pack stamped steel rocker arms?
I have the set that came in my 6 pack Roadrunner engine when I bought it in '75. They are supposed to be "thicker" and "heavier duty" than the standard rockers, but I have been unable to find any details of their dimensions or identifying stampings.
Anyone have info as to how to identify these?
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 440 Six Pack Stamped Steel Rockers [Re: rftroy] #1627585
06/02/14 10:45 AM
06/02/14 10:45 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
69 1/2 ?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 440 Six Pack Stamped Steel Rockers [Re: MOPARMIKE69] #1627586
06/02/14 03:27 PM
06/02/14 03:27 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Didn't know there was a difference. If your concern is a performance heavier rocker then just go with ductile iron or steel / aluminum roller rocker.
MLR426
Re: 440 Six Pack Stamped Steel Rockers [Re: rftroy] #1627587
06/02/14 04:00 PM
06/02/14 04:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think you'll find that the thicker rocker arms were strictly aftermarket (Mopar Performance) and they were thicker only in the pushrod socket area.
The '69-'71 factory parts manual shows only one P/N for 440 rockers.
Re: 440 Six Pack Stamped Steel Rockers [Re: John_Kunkel] #1627588
06/02/14 04:50 PM
06/02/14 04:50 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,
Supposedly the 69 1/2 engine specs.
SPECIFICATIONS
ENGINE
* CARBURETORS: 3 HOLLEY 2 BARRELS ,VACUUM END CARBS, 1350 CFM TOTAL
* INTAKE MANIFOLD: EDELBROCK ALUMINUM
* CRANKSHAFT: SAME AS STANDARD 440, SPECIALLY SELECTED AND SHOT PEENED
* PISTON RINGS: 440 MAGNUM STYLE EXCEPT TOP RING IS MOLY FILLED
* CAMSHAFT: SAME AS 440 MAGNUM EXCEPT IT HAS LOW TAPER PROFILE TO RESIST WEAR
* VALVE LIFTERS: SAME AS 440 MAGNUM EXCEPT .0005" UNDER SIZED AND FLAT FACED
* TIMING CHAIN /SPROCKETS: SAME AS 440 MAGNUM, NYLON SPROCKET -3 BOLT MOUNTING
* ROCKER ARMS:SIMILAR TO 440 MAGNUM EXCEPT STAMPED FROM HEAVIER GAUGE STEEL
* VALVES: SAME AS 440 MAGNUM EXCEPT CHROMED STEMS
* VALVE SPRINGS/DAMPERS:ALL NEW HIGH LOAD
* DISTRIBUTOR:NEW PART NUMBER,PRESTOLITE,DUAL-BREAKER
* OIL PUMP:SAME AS STREET HEMI
* EXTRAS: CARB SHUTOFF SOLENOID,SPECIAL THROTTLE LINKAGE,COIL BRACKET
* AIR CLEANER: OVAL UNIT WITH SEAL THAT FIT AGAINST FIBERGLASS HOOD FOR FRESH AIR
Re: 440 Six Pack Stamped Steel Rockers [Re: 62maxwgn] #1627589
06/03/14 12:12 AM
06/03/14 12:12 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
What are the markings on them? One way to tell is they have a smaller more rounded hole for the rocker shaft than the lighter weight rockers. My old ones have stampings in them starting with prefixes like 1E and 2E with 2-3 digit numbers following. For example, 1E49, 2E306, 1E306, 1E309,etc. I don't know what the stamped markings mean but they are original A12. The numbers are not generally consistant and all over the place. The regular 1969 383/440 rockers have more of an egg shaped hole where they fit over the rocker shaft. One thing incorrect about the list above, A12's did not come with a 3 bolt nylon timing gear. I've had two low mileage originals and all the cams were one bolt with nylon gears. The 3 bolt was standard for the 1969 Hemi with a double roller timing chain and the double roller apparently was also standard on 70/71 440-6's but not 1969 440-4 or 440-6 packs.
Re: 440 Six Pack Stamped Steel Rockers [Re: RoadRunnerJD] #1627590
06/03/14 12:38 AM
06/03/14 12:38 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The rockers for my 70 440-6 are off. I will try and post a pic. My 69.5 A12 bee had a single bolt cam where my 70 had the three bolt.
Re: 440 Six Pack Stamped Steel Rockers [Re: fastmark] #1627591
06/03/14 12:50 AM
06/03/14 12:50 AM
Warrenton, VA
Warrenton, VA
Another...these are an extra set of shot peened and polished 69 1/2 that I advertised on here a while back. Maybe if the stamping starts with a 1 or a 2 number, it means an exhaust or intake rocker?
Re: 440 Six Pack Stamped Steel Rockers [Re: RoadRunnerJD] #1627592
06/03/14 02:41 AM
06/03/14 02:41 AM
USA
rftroy Offline OP
rftroy  Offline OP
USA
I see what you mean about the very round hole for the shaft. Mine look like that.
Mine, though, all have stampings that begin with 1E.
The right rockers are marked 1E310, except for one, which is marked 1E314.
The left rockers have 1 marked 1E195, 2 marked 1E196, and 5 marked 1E197.
Anyone know if standard arms have similar markings?
I miked the thickness of the metal just above the rocker shaft hole at 0.140".
I have a vague memory of comparing these to 383 arms many years ago and finding they were thicker; I'll have to dig up a set and check again.
I pulled out the 69 and 70 parts books, and 69 has one left and one right part number for all 383 and 440. 70 has those same part numbers, except there are two, new for 1970, numbers for the 440 3-2 bbl rockers.
The D.C. manuals, however, state that all Six Pack engines, 69-71, had the heavy duty rockers.
Robert
Re: 440 Six Pack Stamped Steel Rockers [Re: rftroy] #1627593
06/03/14 10:45 AM
06/03/14 10:45 AM
Warrenton, VA
Warrenton, VA
Looks like you have the heavy duty ones
Re: 440 Six Pack Stamped Steel Rockers [Re: rftroy] #1627594
06/03/14 03:00 PM
06/03/14 03:00 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Robert
You are not going to find the 6bbl parts listed in the 69 parts manual , there is a supplement on pink pages for the 69 parts manual , that is where you will find the parts numbers for the A12 engines.
Re: 440 Six Pack Stamped Steel Rockers [Re: JohnRR] #2956848
08/24/21 09:28 AM
08/24/21 09:28 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Fastmark is correct, singlebolt cam on 69-1/2.
Bought one new and changed the cam myself, (SSH-25),
still running one of those cams on our 70 and love it.
Joe
PS 62maxwgn, thought I remember shot peened rods too?
Re: 440 Six Pack Stamped Steel Rockers [Re: jlatessa] #2956887
08/24/21 11:05 AM
08/24/21 11:05 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Joe
That SSH-25 is a great cam. up I've read that one of the DC Purple Shaft cams was patterned after the SSH-25 but something got lost in the translation. Same way with the SSH-44.
Re: 440 Six Pack Stamped Steel Rockers [Re: jlatessa] #2957047
08/24/21 07:45 PM
08/24/21 07:45 PM
A727Tflite Offline
A727Tflite  Offline
Joe
The 69-1/2 rods have a separate part number because they were shot peeled. They look identical to the 4 barrel rod.
They had a unique paint mark applied to them when new.
Re: 440 Six Pack Stamped Steel Rockers [Re: A727Tflite] #2957195
08/25/21 09:41 AM
08/25/21 09:41 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Joe
I'm not sure that is correct. According to this TSB, the '69 1/2 rods were Magnagloed (NDE for cracks) and that was all.
Six Pack TSB
Re: 440 Six Pack Stamped Steel Rockers [Re: 6PakBee] #2957215
08/25/21 10:41 AM
08/25/21 10:41 AM
A727Tflite Offline
A727Tflite  Offline
Joe
Six Pack TSB
My bad. Looking at the TSB I must have confused the crank shot peening with the rods. I knew the rods had “100%” somethin’ done to them. I have an original set still.
Re: 440 Six Pack Stamped Steel Rockers [Re: A727Tflite] #2957249
08/25/21 12:25 PM
08/25/21 12:25 PM
moparx Offline
moparx  Offline
after reading the six pack TSB, i'm left wondering where the "heavier 6 pack rods" story came to be ? shruggy
beer
Re: 440 Six Pack Stamped Steel Rockers [Re: moparx] #2957257
08/25/21 12:39 PM
08/25/21 12:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
beer
That started in '70 when all the externally balanced 440 HP engines got the 'heavy rods'.
Re: 440 Six Pack Stamped Steel Rockers [Re: 6PakBee] #2957707
08/26/21 05:50 PM
08/26/21 05:50 PM
moparx Offline
moparx  Offline
thank you sir ! you cleared a few cobwebs out of the corners ! bow
just a little time difference between july of 69, and when the external balance engines came to be, for the 70 model year.
keep reminding me guys ! i need it. hopefully, your mind[s] will retain what mine doesn't in the later years ! biggrin
beer
