1998.5 3500 CTD question #1626956
05/31/14 06:49 AM
05/31/14 06:49 AM
Hawley, Texas
shinnery Offline OP
super street
shinnery  Offline OP
super street
Hawley, Texas
I have proved to myself I am not getting voltage to my lift pump (in the tank), can this only be the Engine Control Module or is there a combination of inputs the ECM needs to tell the pump to pump? All the relays and fuses seem to be good. I will probably add a relay off a (start and run) fuse in the junction box before I replace the ECM on the side of the engine. $$$$ This truck is only showing 324K miles. NP4500.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: 1998.5 3500 CTD question [Re: shinnery] #1626957
05/31/14 10:26 AM
05/31/14 10:26 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Stock lift pump on my 2000 was on the rear of the engine behind the Cup filter,
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: 1998.5 3500 CTD question [Re: 440PURSUIT] #1626958
05/31/14 01:44 PM
05/31/14 01:44 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The 24 valve motor introduced in 98 1/2 had the first of the electric lift pumps and it was hung on the side of the motor behind the fuel filter canister. The common rail injected motors (introduced in 2003) had their lift pumps in the tank. If your truck is otherwise stock, an upgrade is to install a FASS DDRP pump on the frame rail ahead of the fuel tank and push your fuel up to the filter. The old pump tries to suck fuel up hill and it kills them. Leave the old fuel pump bracket on the engine, it covers a hole in the block and will leak oil if removed. You will need a fuel pump relocation kit and the pump. You can get all the parts and info at www.genosgarage.com. They helped me when I had my CTD. Sometimes, I wish I still had it. Every man needs a locomotive once in his life.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 1998.5 3500 CTD question [Re: Polarapete] #1626959
05/31/14 02:21 PM
05/31/14 02:21 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
not all true. my 2004 ctd had the fuel pump mounted on the back side of the fuel filter housing.I don't think the intake fuel pump came factory until 2005.when my fuel pump quit dodge put a retro fuel pump kit in my tank.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 1998.5 3500 CTD question [Re: mopar65] #1626960
06/01/14 12:58 AM
06/01/14 12:58 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I cannot dispute that all I know is that on my 2002 it was that way and from what I read about the Cummins here
http://www.genosgarage.com/GenosGarageTechArticles/TDR56_DodgeFuelTransferPump.pdf
this is the way to solve your problem.
2008 Honda Element
Re: 1998.5 3500 CTD question [Re: Polarapete] #1626961
06/01/14 02:28 AM
06/01/14 02:28 AM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Yeah.... hang an electic motor on your frame rail where it's a prime target for rain/snow/road salt etc... No thanks.
...and on to the original question. I'll go out on a limb here and "assume" that you know what you're working on. You've stated you have no voltage to the "in tank lift pump". That would mean it's had the retrofit kit installed that mopar came up with for an in tank installation. As noted....your truck was born with a lift pump located on the engine right behind the fuel filter canister. This would mean that you have had a relay and small wiring harness installed as part of this upgrade. There is an inline fuse for this pump..... is it ok? There is also a relay that is energized by the "original" lift pump 2 pin plug that attaches to the add on harness. I'd be doing a voltage test at that connector. It's simply a B+ directly from the ECM and a ground. If no voltage there, yes, it's possible the driver in the ecm has failed. If that's the case I'd do exactly what you mentioned..... find a key on B+ source and use that to energize your relay.
Re: 1998.5 3500 CTD question [Re: shinnery] #1626962
06/01/14 09:00 AM
06/01/14 09:00 AM
Franklin County VA
DRTMopar Offline
super street
DRTMopar  Offline
super street
Franklin County VA
Look on the side of the block near your fuel filter there is your lift pump. It will have a 2 pin connector going to it. They are common for going out. It will usually take your VP44 with it.
http://dieselconversion.com/sites/dcs/files/kbase-pics/24-valve-lift-pump.jpg
08 2500 6.7 6sp 79 soon to be 440-4speed Adventurer 100 79 Warlock II 79 Lil Red
Re: 1998.5 3500 CTD question [Re: mopar65] #1626963
06/01/14 08:24 PM
06/01/14 08:24 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
That's correct the intank pump did not start until 2005, however if an earlier truck with a filter housing mounted pump had a pump failure it would have been replaced with the intank module.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 1998.5 3500 CTD question [Re: dusturbd340W5] #1626964
06/06/14 07:53 AM
06/06/14 07:53 AM
Hawley, Texas
shinnery Offline OP
super street
shinnery  Offline OP
super street
Hawley, Texas
My bad. Sorry I took so long to get back but everything seems to take longer at 73.5 for some reason. I goofed, I looked under the hood and did not see the original "carter" looking pump and thought there was not a pump there. I got the connector loose on top of the tank and checked for voltage at the outer two pins and nothing there. That is when I asked about the control of the ECU. Went to town and bought parts to apply 12v to the tank and nothing happened. Got to looking better and discovered an "airtex" style pump that I thought was part of the starter originally. I put 12v to this pump and it will not run and I get 12v on the disconnected cable when I cycle the Ign. SW. so the ECU is working. As this is an economy deal, I ordered a pump from Rock Auto using a Mopar Action disc. I want to hear this thing run before I get too much into it. I am still less than $1300 including the pump from Rock. Just a well hail dinged 98.5 3500 QuadCab CTD 5 sp. showing 324K miles, possibly an ex Hot-Shot. I found it has air bags but the comp. is MIA. Also had some sort of an air hookup, on the side of the bed, for trailer brakes??
Bryce
