Re: Shifter cable clearance with TTI headers and Indy heads
[Re: mshred]
#1626684
05/30/14 12:40 AM
05/30/14 12:40 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
what length shifter cable are you using...
usually a 4 ft cable will fit without any header problems...the 5 ft cable causes problems.
I put heat wrap around tube no. 7...and heat wrap around the shifter cable.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1626685
05/30/14 12:42 AM
05/30/14 12:42 AM
Posts: 3,420 Toronto
mshred
Toronto
If I am not mistaken it is a 5ft cable. It came with my Hurst pro stick when I bought it. I still don't understand why they don't make them rear exit instead of front, but thats a whole other deal.
With a 4ft cable there are no issues at all? The cable just stays in between the two tubes with lots of room around it?
[Re: mshred]
#1626686
05/30/14 12:52 AM
05/30/14 12:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would try the 4' one but dont get the heavy duty... they dont like to make tighter loops
[Re: pleasantk]
#1626689
05/30/14 04:23 PM
05/30/14 04:23 PM
mshred
Toronto
I ran mine over the top of the trans to the passenger side and loops down between the motor and trans on the bottom side. Slid some transmission rubber line over the cable (on top side that lays on top of trans) for extra protection. No tight bends and nothing remotly close to the cable. If you want I will climb under the car tonight and get a picture of it.
A picture would be great if you could.
[Re: shorthorse]
#1626691
05/31/14 09:23 AM
05/31/14 09:23 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I usually run a 4' cable. I have a brand new 5' B&M race cable sitting here that came with my shifter, I'm probably gonna sell it and put that money towards a 4' cable. The 5' tends to run up near the starter and header.
