Can I get a read on this plug? #1626375
05/29/14 11:21 AM
05/29/14 11:21 AM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I have recently read some conflicting info on reading plugs even conflicting on what I think I know and even some info I was unaware of. Any input would be apreciated.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Can I get a read on this plug? [Re: mopar346] #1626376
05/29/14 11:54 AM
05/29/14 11:54 AM
Georgia
Steve Bryant Offline
Georgia
Interesting look. Strap looks great to me but the carbon around the threads looks like you are a little rich at times. Maybe the idle is rich?
If I had to take an educated guess I would say you have a rich idle but the mixture above idle looks pretty good.
Sometimes photos can lose/gain color and I can't see the condition of the center or ground electrodes but that is my read on it.
Are you experiencing any drivability problems or just looking at the plugs?
Re: Can I get a read on this plug? [Re: Steve Bryant] #1626377
05/29/14 12:28 PM
05/29/14 12:28 PM
mopar346 Offline OP
mopar346  Offline OP
Somewhat but I want to hold that info until some opinions, don't want to taint the pool with anything at this point. I will add it later though, thank you for your input.
Re: Can I get a read on this plug? [Re: mopar346] #1626378
05/29/14 12:29 PM
05/29/14 12:29 PM
Georgia
Georgia
Understood and good idea! In the meantime, can you post another photo at a different angle?
Re: Can I get a read on this plug? [Re: Steve Bryant] #1626379
05/29/14 12:32 PM
05/29/14 12:32 PM
mopar346 Offline OP
mopar346  Offline OP
Not really I changed some things and drove 50-60 miles so they are different, the changes had some ill effects and I am considering reversing all of them. That is the only picture I took at the time, I am gonna change them in a bit and I will outline the changes I made to the car at that time. Please check back later as it will be interesting to see your read on the changes.
Re: Can I get a read on this plug? [Re: mopar346] #1626380
05/29/14 12:36 PM
05/29/14 12:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
I don't like to see the little brown, black or shiny dots on the porclyn I would either change the heat range down one or two heat ranges colder or change the part throttle cruise mixtuure to be richer a small amount, not a bunch richer Can you see a narrow black line like a thin pencil mark across the ground strap anywhere? If so where is it in relation to the body or the end of the strap? I like my plugs to be clean like those without the dots, I like to see the pencil line halfway up the ground strap, in the middle of the curve A hot plug will mask a lot of things in the combustion chambers Tune, tune tune until you are absolutely happy You can make them perfect
Re: Can I get a read on this plug? [Re: mopar346] #1626381
05/29/14 01:20 PM
05/29/14 01:20 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
That plug must have very little miles on it and I mean very few . If it got 5-10-15 - thou on them , then you got coolant getting on that plug . Too clean too white .
Re: Can I get a read on this plug? [Re: mopar_man] #1626382
05/29/14 01:49 PM
05/29/14 01:49 PM
mopar346 Offline OP
mopar346  Offline OP
Try 850 miles, I am fixin to drive it about 3500 miles round trip and want things (read mixture)to be right.
Re: Can I get a read on this plug? [Re: Cab_Burge] #1626383
05/29/14 01:52 PM
05/29/14 01:52 PM
mopar346 Offline OP
mopar346  Offline OP
Cab, Autolite AP65s, not really a hot plug is it? Not a real destinct line on the strap. I saw the black dots, not really enough to be detonation in my mind, timing is argueably low infact at this point. One change I made was moving the timing up and ended up with too much total, now plugs are peppered pretty good, no shiny that I saw though.
Re: Can I get a read on this plug? [Re: mopar346] #1626384
05/29/14 10:44 PM
05/29/14 10:44 PM
johnmilner Offline
johnmilner  Offline
check your carb.
Re: Can I get a read on this plug? [Re: johnmilner] #1626385
05/29/14 11:02 PM
05/29/14 11:02 PM
mopar346 Offline OP
mopar346  Offline OP
check your carb.
For????
Re: Can I get a read on this plug? [Re: mopar346] #1626386
05/29/14 11:02 PM
05/29/14 11:02 PM
mopar346 Offline OP
mopar346  Offline OP
Here is a picture of the plugs replaced today, this is the same plugs as above but with a jet change from 64s to 67ys briefly and then 65Hs, there is only about 50-60 miles from the earlier picture, it also had way too much total timing during this time period. I took 9 pictures but this is the only one that I thought had a chance of being able to be seen in a post. It is heavy black around the thread base, definitely rich and even black on the porcelain indications of the high timing. This all started because I was getting a slight surge at highway speeds (2700ish RPMs), other than that it ran extremely well with only an occasion minor hot soak start issue and an occasional low idle. I begin to address it like a lean surge starting with the jet change and then began to go through the 6 pack set up as outlined by Tom Quad and Dayclona, at this point the run quality began to deteriorate, mostly the idle quality but it also led to the high timing setting. It would not idle below about 1200 or so I started to return to my base setting (I built the carb and fired it up about 900 miles ago now) during this I could not get my idle back and since it was around 1200 the mechanical advance was coming in so I had to resort to setting total timing at 34, while doing this I realized that the vacuum advance added nothing to the total timing. I found the canister was leaking freely? In taking it apart I found that the spring in the vacuum advance had the plate in a bind and that was the origin (I think) of too much timing at idle. I also found another issue with the distributor as well, so I am replacing it even though it is new. So here is what I think happened, the surge was the first sign on the vacuum advance going bad and as I was adjusting it was getting worse until complete failure, it was doing this while I was making the adjustments so it was really confusing me. The long and the short of it is I plan to replace the distributor and go back to me base settings and see if he surge is gone and everything else returns to normal, the surge was slight so I could live with it if I cant get it out.
One of the reasons for my concern is I am fixin to run it about 3000 or so miles and I don’t wont it running lean.
So does anyone see a reason to be concerned with the condition of the plugs in the first picture, this was where it ran it’s best for 800 miles with the 64s and my settings. I know it’s a long drive but it’s a car that is what it was built for.
Thanks, Kevin
Re: Can I get a read on this plug? [Re: mopar346] #1626387
05/29/14 11:25 PM
05/29/14 11:25 PM
mopar346 Offline OP
mopar346  Offline OP
I took 9 frickin picture and this was the best one, I think it is because I took them in the sunlight. I can get better ones tomorrow if it matters, I replaced these plugs. This is what happened with the 67s for a breif time and then 65Hs and way too much timing. It appears heavy black on the base and even some black on the procelean almost like pepper. Definitely running rich so I am going back to the 64s tomorrow.
It appears to me that the original picture shows the mixture good to slightly rich. I am getting a slight surge at highway speeds, 2700ish RPMs. It is a 340 6 barrell that performs well in every other aspect. I started chasing the issue like it was a lean surge but after going through all the set ups as outlined by Tom Quad and Dayclona it began to run poorly at idle(but this was with the 65Hs) essentially not wanting to idle below about 1200. During the process I found a few interesting things with my distributor but I believe they were beginning to occur and the surge was the first sign, it then went down hill while I was doing the set up so I it was giving me bad readings. I am in the process of fixin that and then I can get back to the set up, but frankly I am gonna go back to my settings before I started monkeying with it, it seemed to work well.
So does anyone disagree that the first picture likes acceptable for 800 mile plugs and I have no reason to be concerned about a 3000 mile trip?
Thank you, Kevin
Re: Can I get a read on this plug? [Re: mopar346] #1626388
05/29/14 11:54 PM
05/29/14 11:54 PM
Georgia
Georgia
So I wish you lived near me and I would loan you my A/F gauge and sensor. That $130 device took all the guesswork out of my carb tuning and I was able to get a Eddy 750 to function cleanly and without a lean stumble on a 440.
If you are not in too much of a rush, I would consider doing something like that. Amazon sells them for less than $150 and it is an excellent tool for doing exactly what you are doing. I got a local shop to weld a couple of O2 bungs in my exhaust and it cut my carb tuning time and guesswork down to something very manageable.
I don't have the wizard skills to read spark plugs to the level of knowing where the A/F mixture is at Idle, cruise circuit, low-vacuum cruise and WOT.
I am sure there is a wizard here who can look at the photos and tell you what to do since there are some very very smart people on this board like Mr. Cab. BUT, if you have a few days to get in a gauge, around $150 and a local welding shop to install some bungs I can guarantee you will find a solution pretty quickly.
Re: Can I get a read on this plug? [Re: Steve Bryant] #1626389
05/30/14 12:10 AM
05/30/14 12:10 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you, where abouts in Ga are ya, I'm only a few miles from the border. The problem with using those for me would be the welding in the bungs, no way I am drilling into my Accurate exhaust, damn near a grand. This is an AAR and pretty close to correct so mods like that aint gonna happen, it would make it easier though. Here is one of the sites I used to learn a little more about plug reading, i have always read the procelein but I wasn't really reading the true story. If you want to know more just google plug reading basics and all sorts of stuff comes up. This one is very much to the point and simple.
http://www.wallaceracing.com/plug-reading-lm.html
Re: Can I get a read on this plug? [Re: mopar346] #1626390
05/30/14 12:22 AM
05/30/14 12:22 AM
Try putting in one Autolite # 64 in it(in #7 cylinder) and then drive it for a short,5 to 10 miles, part throttle cruise and look at that plug One heat range can make a big difference once you get real close to the best tune If you like the part throttle cruise look, then take it out again and wack it at WOT for 12 to 16 seconds in high gear, if you can safely, and then look at it again as soon as possible, take the tools with you and If it stills has those black or shiny dots on the porcyln look at your fuel supply for WOT
Re: Can I get a read on this plug? [Re: mopar346] #1626391
05/30/14 12:25 AM
05/30/14 12:25 AM
Georgia
Georgia
So I live near the ATL Airport. I have Accurate exhaust too, but I have "hidden" the bungs so they are not obvious.
I have heard of people pushing the sensor far up the pipes but you couldn't drive that way of course and would be limited to tests without a load. It may still help and you are welcome to borrow it.
Re: Can I get a read on this plug? [Re: Cab_Burge] #1626392
05/30/14 12:39 AM
05/30/14 12:39 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you, I'll do that when I get the distributor back in and my settings back to where I had them.
Re: Can I get a read on this plug? [Re: Steve Bryant] #1626393
05/30/14 05:25 PM
05/30/14 05:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Hey Steve what gauge was only 130?
Re: Can I get a read on this plug? [Re: GTX MATT] #1626394
05/30/14 07:06 PM
05/30/14 07:06 PM
Georgia
Georgia
Innovate Motorsports 3844. They are new on Amazon and Ebay for $140 but there are some used ones that pop up for less money. Right now, there is a used one on Amazon for $143. A few months ago one popped up for around $130 and so I snapped it up.
