Lifter bore measurment????? #1626118
05/28/14 04:41 PM
05/28/14 04:41 PM
In the 8's
FY1TA Offline OP
FY1TA  Offline OP
In the 8's
What type of gauge would you use to check the lifter bore size ? Thx
Re: Lifter bore measurment????? [Re: FY1TA] #1626119
05/28/14 04:51 PM
05/28/14 04:51 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
.50-1.00" dial bore guage. You can use snap gauges, but no where near as telling or accurate in my opinion, unless you use them a lot and have a good feel for them.
RIP Monte Smith
Re: Lifter bore measurment????? [Re: CompWedgeEngines] #1626120
05/28/14 06:31 PM
05/28/14 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I bored my bushings out I had to use my snap
gauges due to my bore gauge was sent back to the company
for repairs... they are real close but I took multiple
readings per bore to make sure I was right
Re: Lifter bore measurment????? [Re: CompWedgeEngines] #1626121
05/28/14 11:56 PM
05/28/14 11:56 PM
Same thing on a set of inside calipers, dial bore gauges are way better I don't have one(dial bore gauge) that will measure less than 1.00
Re: Lifter bore measurment????? [Re: Cab_Burge] #1626122
05/30/14 09:46 AM
05/30/14 09:46 AM
In the 8's
FY1TA Offline OP
FY1TA  Offline OP
In the 8's
Ended up borrowing a dial bore gauge . Worked great . Thx for the info.
