2000 ram 2500 overcharging now dead #1625924
05/28/14 01:17 AM
05/28/14 01:17 AM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
Title pretty much sums it up. Friend of mine has a v10 in a 3/4 ton pickup. He replaced the alternator and it started overcharging. Shut it off and now he has lost all gauges, fuel pump, dome light and cigarette lighter. All the fuses are testing good and the OBD2 will not link to the matco scan tool we have access too. Any ideas??????? Computer maybe???? It was just replaced by the dealer for almost a thousand bucks so he is hoping that is not the problem. Can a person get another one from a salvage yard and try that?
Re: 2000 ram 2500 overcharging now dead [Re: Posest] #1625925
05/28/14 02:46 AM
05/28/14 02:46 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Fried PCM
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 2000 ram 2500 overcharging now dead [Re: astjp2] #1625926
05/28/14 02:44 PM
05/28/14 02:44 PM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
Would that be the ECM under the hood on the passenger side firewall? Can one from a salvage yard be bought and tried without dealer flashing it?
Re: 2000 ram 2500 overcharging now dead [Re: Posest] #1625927
05/28/14 04:19 PM
05/28/14 04:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Dome light and cigarette lighter have nothing to do with the ECM working. I'd start checking for a bad fusible link or some other reason for no power. Find a wiring diagram and trace the hot wires. You said all the fuses checked good does that include the under hood stuff and well as the interior ones? Do the dash warning lights come on when you turn on the key?
Re: 2000 ram 2500 overcharging now dead [Re: stumpy] #1625928
05/28/14 09:33 PM
05/28/14 09:33 PM
IN
ahy Offline
ahy  Offline
IN
Is the battery itself OK? Overcharge could have cooked it. A test light and voltmeter should tell.
Re: 2000 ram 2500 overcharging now dead [Re: ahy] #1625929
05/28/14 10:39 PM
05/28/14 10:39 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
By checking the fuses , what did you do ? did you just check the fuse or did you check and see if there was voltage across each one . I think its a fuseable link somewhere .
Re: 2000 ram 2500 overcharging now dead [Re: mopar_man] #1625930
05/28/14 11:12 PM
05/28/14 11:12 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I see this all the time! "I checked all the fuses"...meaning someone pulled them out and looked at them.To check fuses properly they need to be in the circuit and powered up...then check for voltage on BOTH sides of the fuse!! A fuse can look good and be open or look good and not have power TO it! Also make sure you check ALL fuses in ALL fuse blocks!
Re: 2000 ram 2500 overcharging now dead [Re: Dcuda69] #1625931
05/29/14 11:37 AM
05/29/14 11:37 AM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
I tested all fuses with a test lite. I tested for power at obd2 port. Contacted local dealership and they said pcm issues also. Have a new one ordered.
Re: 2000 ram 2500 overcharging now dead [Re: Posest] #1625932
05/29/14 03:36 PM
05/29/14 03:36 PM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
Tested all fuses under hood, inside cab next to drivers door and there is power at the obd2 port under the dash. All were tested with a stab light. Headlights work fine. Door dinger works with key in the off position but stops making noise when key is turned to acc or run position. Fuse for the cigarette lighter is good but lighter, horn and interior lights will not turn on. The tail and brake lights work also. Engine will crank over with key but no fuel pump or spark. Battery has been replaced already since overcharging. Have not been able to locate a fusible link. That was the first struggle to look for. IOD fuse was removed and replaced after testing with a test light just to verify good connection in fuse panel.
Re: 2000 ram 2500 overcharging now dead [Re: Posest] #1625933
06/07/14 02:40 AM
06/07/14 02:40 AM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
Replaced the ECM with a refurbished one. The pickup now starts and runs. Lighter socket works now. Still no gauges, no dome light or airbags. Looks like the CTM computer fried as well as the ECM. This has been an electrical nightmare!
