Re: Slant 6 alternator bracket
[Re: pleasantk]
#1625805
05/27/14 08:51 PM
05/27/14 08:51 PM
Posts: 706 USA
rftroy
USA
Slant 6 and small block use completely different methods to hold alternator. Here is a slant 6 bracket. It is cast iron (possibly steel) and bolts to the side of the block. The small block mounts to the head, at the back of the alternator, with spacers and has a flat steel plate which holds the front.
No way to interchange either.
This picture has instructions to the machinist to adapt bracket to hold a newer style Denso alternator.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#1625806
05/27/14 09:08 PM
05/27/14 09:08 PM
Posts: 706 USA
rftroy
USA
To answer the rest of your questions:
The bracket is unique to slant 6s.
6 and SB used the same alternators within years, possibly different amperage ratings. The cases were the same dimensionally.
Here is how the alternator mounts to the bracket, although this is a Denso.
Robert
[Re: rftroy]
#1625807
05/27/14 09:14 PM
05/27/14 09:14 PM
Posts: 706 USA
rftroy
USA
Here is how the SB alternator mounts. Image from the Bouchillon Performance Engineering website. You might try: http://www.bpeusa.com/BPE5250CHAC_C.aspif you want correct brackets. RT
