need help with identification. #1625764
05/27/14 06:02 PM
05/27/14 06:02 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Can anyone identify what this small panel is and where it goes? Off a 1970 Challenger and was removed during my restoration. Has numbers on it as follows EM F 08 size is 23.75 long X 4" high on its highest point. Its also bevelled on all four sides. Thanks in advance
Re: need help with identification. [Re: sailboat] #1625765
05/27/14 06:33 PM
05/27/14 06:33 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Since they are attached at the little point, I'm almost positive those are the wiring covers that go along side the interior bottom door sill. They protect the tail light harness run from the carpet.
They are just spot welded on and maybe they broke during teardown. Or they might have been just under the carpet loose if a factory worker left a loose one in there he didn't use/forgot.
Re: need help with identification. [Re: autoxcuda] #1625766
05/27/14 07:50 PM
05/27/14 07:50 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Thanks. Makes sense. Anyone know how it attachs and is there more than just the one plate?
Re: need help with identification. [Re: sailboat] #1625767
05/27/14 08:31 PM
05/27/14 08:31 PM
So Cal
So Cal
Spot welded on.
Should go from kick panel to edge of rear seat or so.
Re: need help with identification. [Re: sailboat] #1625768
05/27/14 10:37 PM
05/27/14 10:37 PM
NC
1970A66 Offline
1970A66  Offline
NC
Called "floor wiring covers"
I bought new ones and was able to find the original spot weld locations on my floor boards. Then I lined up the new ones to the original spot welds and tacked them in.
http://www.autometaldirect.com/images/6/442-2570-S_800.jpg
http://www.mattsclassicbowties.com/contents/en-us/p6397.html
Installed (but flipped up instead of flat on the floor):
http://www.cuda-challenger.com/cc/index.php?topic=97521.0
Re: need help with identification. [Re: sailboat] #1625769
05/27/14 10:50 PM
05/27/14 10:50 PM
CT
1932chrysler Offline
CT
This is the only photo I have if this is the part in question
Early build 71
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
