Low gear set q's
#1625757
05/27/14 05:59 PM
05/27/14 05:59 PM
Posts: 2,937 A shed in England
Tig
A shed in England
OK, New motor makes peak torque @ 5300 and peak hp @ 6400 There is enough HP to go 150mph+. I'm figuring a 4:10 rear is too much since we go 7000 @ 142mph. It's a Dana 60 and the next gear down is a 3.73, would you use stock 727 g'box ratio's or a low gear set with a 30.5 inch dia tyre (including growth)? I've just broke the diff and probably damaged the box too so both will likely need rebuilding TIA.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Low gear set q's
[Re: Tig]
#1625758
05/27/14 06:44 PM
05/27/14 06:44 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"we go 7000 @ 142mph. " TIG that sounds like a lot of RPM for 142 MPH with 4;10's. We turn 7000 at about 152 MPH with 4;10's. "I've just broke the diff " Wow must be a lot of power with new motor Mike
[Re: 70satelliteguy]
#1625759
05/27/14 07:13 PM
05/27/14 07:13 PM
Tig
A shed in England
What size tyre? This is with the 572 motor, 655 isn't in yet.
[Re: Tig]
#1625760
05/27/14 10:06 PM
05/27/14 10:06 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"What size tyre?" Tig we run the 31.0/14.0/15 Goodyear. Not that far off from your 30.5 tire! I could be wrong but it seems like you could have a bit too much slippage in your converter Just this past Friday night we went thru the traps with the shift light just blinking(set for 7000 rpm) at 154.03 MPH. Dana 4;10's . I tried the low gear set once with this combination but it did not help with 60 fts. at all. Car still will go 1.31 with stock set Mike p.s. Could you elaborate on breaking the Dana
#1625762
05/27/14 11:59 PM
05/27/14 11:59 PM
Tig
A shed in England
Tyre is designated 29.5 x 10.5, I included growth. We broke teeth off the crownwheel, looks like a few had been cracked for a while . I'll post some pic's up soon. I figured we'd gain some torque multiplication back with the low gear set, but was wondering how they'd hold up. Motor made 950ft/lb peak btw and calculated more with a 2.74 and 3.73 than a 2.45 and 4.10's.
[Re: Tig]
#1625763
05/29/14 09:30 PM
05/29/14 09:30 PM
Posts: 9,882 MI, usa
dvw
MI, usa
Mine goes thru at 6900@147 with a 4.10 and 10.5x31 M/T. Doug
