Paint: clear coat white spots? #1625699
05/27/14 01:15 PM
05/27/14 01:15 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
I have Ditzler clear coat, and in a couple of spots, there is like a very very fine "dust" IN the paint. It appears as very small white spots. This is on a black car, and probably any other color it wouldn't show. It is NOT dust. On a door the spots are some what random. After buffing, it looks like a fine dust has settled. Any ideas? I was going to touch up the door, but then noticed the rear quarter is not right either. On the quarter, it is all in one spot about 6 inches in diameter. What do you think?
Re: Paint: clear coat white spots? [Re: SportF] #1625700
05/27/14 02:34 PM
05/27/14 02:34 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Chances are very high those spots are where you or someone sanded or buffed through the clear coat. The base coat has no UV protection and it will chalk if it isn't protected. Solution in that case is to color sand the area (to remove the base coats oxidation) and re-clear the panel. Good rule of thumb... If you're going to color sand a clear coat you need at least three coats of clear, and four is better.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Paint: clear coat white spots? [Re: Centerline] #1625701
05/27/14 03:03 PM
05/27/14 03:03 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
No, this is all fresh paint. The quarter was painted last fall, the door 3 weeks ago. I have sanded and buffed, and I know its not thru (because I have done that on this car, which is why the quarter was re-painted). By the way, this clear is also out of two different cans.
Re: Paint: clear coat white spots? [Re: SportF] #1625702
05/27/14 04:12 PM
05/27/14 04:12 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I have had this before. It is very small craters in the paint, usually caused by moisture in the line while the paint was shot. Then when you went to sand and buff the residue settles in the craters. Take a tooth pick and see if you can clean out the crater and remove the white residual. If not then it is in the clear and would have to be sanded out and recleared. If they are small enough and do clean out with the tooth pick you can spot them in with clear, resand and buff.
I had that on this trunk and here is the final result after some work.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Paint: clear coat white spots? [Re: MOPARMIKE69] #1625703
05/27/14 07:43 PM
05/27/14 07:43 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
I would agree with you Mike, but my surface is smooth. And this was sprayed with a Grayco unit, one with a hose 1" in dia that comes from a heated turbine compressor. One of these units with little pressure, lots of volume. Well, I guess that could pump moisture too, but I have had the same thing happen on the door with an HVLP sharpe, although not to quite the same extent. I thought this 2 stage stuff was suppose to be easier. This is my first car with the two stage....and it hasn't been working out.
Re: Paint: clear coat white spots? [Re: SportF] #1625704
05/28/14 10:01 AM
05/28/14 10:01 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
If it is not little craters then it has to be something in the clear or even on the black base coat. 2 stage is way easier than single, but if you get something on the base before clear it will show up. If you get trash while you shoot the clear it will show up. Plus you are doing black, by FAR the most difficult paint to get right. Did you do anything to the base before shooting the clear? Sand ? Wipe?
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Paint: clear coat white spots? [Re: SportF] #1625705
05/28/14 11:41 AM
05/28/14 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sounds more like a case of gassing out/solvent pop,....no photos of the area?
what was the primer/sealer colour prior to laying down the base colour
Mike
Re: Paint: clear coat white spots? [Re: MOPARMIKE69] #1625706
05/28/14 11:43 AM
05/28/14 11:43 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i would suggest buying a microscope like this, http://www.radioshack.com/product/index.jsp?productId=2179604, and actually see what the white spots are.
i have one like it that i have used for the past 30 years on paint problems.
look at the spots with the microscope ans see what they look like. maybe pick at one spot with a razor blade for a more detailed look. if you are careful you will not see the damage from the blade. of give the spot a quick touch up.
with your description the spots sound like moisture in the clear. i have seen this a LOT in paint jobs done in a air dry situation. heated air out of a machine can cause condensation in the lines by the time it makes it to the spray gun.
also moisture can form on the cars surface if the temp changes while you are painting.
maybe call the place where you bought the paint from and ask for some help from the paint rep.
this is the reps job to help out with problems like that.
perception is 90% of reality
Re: Paint: clear coat white spots? [Re: DAYCLONA] #1625707
05/29/14 01:36 AM
05/29/14 01:36 AM
New York, USA
Chargerfan68 Offline
New York, USA
Mike
I agree with Mike...This happened to me with a body panel that I shot in the late fall with too cold of a temp. possibly. I probably didn't let the coats flash long enough at that temp.
When I went to wet sand a few days later, I had the same exact problem occur. Looks just like white dust embedded in the clear ,but as smooth as glass.
Re: Paint: clear coat white spots? [Re: Chargerfan68] #1625708
05/29/14 09:24 AM
05/29/14 09:24 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Well, it must be moisture, but I just don't know how to get rid of that.
Maybe I'll wait till winter and do it then.
Actually there is one other thing about this clear and that is the mist seems to bounce off the surface. I've never had so much mist in the air. Again I have tried 3 different guns, different feeds and pressure and it pretty much fills the air. I can turn right around and spray a base coat and get none of that. Has that been anyone elses experience?
Re: Paint: clear coat white spots? [Re: SportF] #1625709
05/29/14 09:31 AM
05/29/14 09:31 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Research "solvent pop"
Sounds like what you have.
Has to do with the paint and painting method
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Paint: clear coat white spots? [Re: SportF] #1625710
05/29/14 11:43 AM
05/29/14 11:43 AM
pa.
dan9 Offline
dan9  Offline
pa.
Humidity ,high temp or painting while it is raining can trap moisture in the paint. Bodymen used to refer to this as "blushing". Reducers have a certain temperature range that can help eliminate this. They speed up or slow down drying time. I have one of those Graco units, I never thought of painting a car with it. That turbine does produce a lot of heat, maybe it dries it too fast.
