Page 3 of 3 1 2 3
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: mshred] #1625598
06/02/14 01:50 AM
06/02/14 01:50 AM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Maybe off topic, but is the engine internal or external balance? I assume internal with the aftermarket steel crank, but thought I'd ask.
Nice numbers
Yes internal. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 360 Street/Strip Bruiser-Dyno results inside [Re: Locomotion] #1625599
06/02/14 01:55 AM
06/02/14 01:55 AM
RAMM Offline OP
RAMM  Offline OP
Raw air numbers really only tell part of the story, creating a charge in the plenum can more than offset "raw" port numbers...particulary when you consider any given intake valve is completely closed roughly 2/3'ds of the time. Not to mention solid fuel volume displaces about ~7.5% of that air in a carb'ed motor. So a raw 300 cf/minute can really only meter ~100 cf within the roughly just over 20 seconds of each minute it gets to do it. And for half of that 20 seconds (on a street cammed motor like this one, more like ~27-28 total in a high RPM race motor) the valve is on it's closing ramp. It's pretty amazing the A/F can get in there (let alone out) as well as it does.
This is exactly why I don't put a lot of stock in intake manifold flow numbers. I have seen 400+cfm heads with sheetmetal TR's lose nothing when flowed on the head and not make any more power than an intake that imposes a severe penalty in flow. Flow just isn't the end all be all--especially when applied to the intake manifold. J.Rob
Going another step from the dual plane that Streetwize suggested, if you weren't so happy with the torque numbers, have you considered a more conservative single plane, like a Holley Strip Dominator or M1 single plane and experiment with 4-hole, tapered and open spacers? I know the original Victor has a bigger plenum than the intakes I mentioned, so I would assume that the SV intake is even bigger.
Was assembled with the parts I had on hand. If I had a Weiand X-Celerator I would have used it. That intake is a torque producer. I was very curious to see just how much of an RPM type 360 these parts would produce. Now I know. I think this engine would make a great street race type "catch up" engine. J.Rob
Page 3 of 3 1 2 3
