Hemi Swaybar? #162554
12/05/08 11:52 AM
12/05/08 11:52 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Is there clearance issues with the skid plate on a Hemi K-member (E-body) if you put a bigger sway bar (1" or 1 1/8")? I seem to remember there being problems with some of the after market sway bars. Any suggestions on a vendor?
Re: Hemi Swaybar? [Re: Kirby] #162555
12/05/08 06:31 PM
12/05/08 06:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I think you could possibly squeeze a 1" bar between the K and skid,.......I know when I put 1 1/4" bar in, I had to cut two welds to pry the skid down, then weld back later, the bar diameter fits ok once it's in,....it's just trying to get the ends of a larger bar to snake thru, is the problem
As far as vendors, I prefere the Hellwig set-ups, they seem to be better engineered, fit better than the Addco's
