Brake master cylinder question. #162519
12/05/08 10:23 AM
12/05/08 10:23 AM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I bought a new master cylinder for my '74 RR.My
question is how do I connect the pushrod into the new master cylinder?
Re: Brake master cylinder question. [Re: 74RR] #162520
12/05/08 11:20 AM
12/05/08 11:20 AM
Andrewh Offline
Andrewh  Offline
manual brakes?
Should be a rubber piece that fits over the end of the pushrod. It locks it into the master cylinder. They are like a buck a piece from one of the advertisers on this site.
Re: Brake master cylinder question. [Re: 74RR] #162521
12/05/08 11:25 AM
12/05/08 11:25 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
+1 on the grommet for the pushrod. I installed the m/c into the car, the pushrod on the brake pedal, lined things up and used the pedal to pop it into place..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Brake master cylinder question. [Re: GoodysGotaCuda] #162522
12/05/08 11:27 AM
12/05/08 11:27 AM
74RR Offline OP
74RR  Offline OP
Thank you all!
