mounting a trans cooler #1625090
05/26/14 01:16 AM
05/26/14 01:16 AM
minnesota
P
president61 Offline OP
P
minnesota
I'm putting a O500 trans in my swinger. I'm using this trans cooler and was wondering if it mattered what direction i have the in and out nipples???
Re: mounting a trans cooler [Re: president61] #1625091
05/26/14 01:27 AM
05/26/14 01:27 AM
Any way is fine, whichever gives you the neatest hose routing
Re: mounting a trans cooler [Re: president61] #1625092
05/29/14 01:42 AM
05/29/14 01:42 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Wash it out good with carb cleaner & air but make sure it has a real 3/8" hose barb that matches the size of your lines or your OD unit will starve/heat up
If you are wanting to use your stock radiator, you can't for this very reason
The first thing Chrysler learned about the OD transmissions was cooling & line size effects on the OD unit itself
Re: mounting a trans cooler [Re: president61] #1625093
05/29/14 11:27 AM
05/29/14 11:27 AM
What Bob said made me think & the OE lines are 5/16" OD & some aftermarket coolers are 3/8 & that pair of brass fittings (npt/inverted flare) that screw into the trans case are available in the next larger size (3/8") so if the passages inside the trans for the fluid going in/out to be cooled are larger than the ID of the OE 5/16" line then I'd think there'd be a bennie to going to the next larger size of line/fittings for more flow . EDIT You would want to drill/npt tap the case while the trans is apart/case is bare
Re: mounting a trans cooler [Re: RapidRobert] #1625094
05/29/14 01:52 PM
05/29/14 01:52 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The A500 from 91 up should already be setup for 3/8" from the factory I know the A518s are
Re: mounting a trans cooler [Re: RapidRobert] #1625095
05/30/14 08:57 AM
05/30/14 08:57 AM
moparx Online content
moparx  Online Content
just watch that the case "nub" has enough meat around it for the oversize drill/tap, because if it doesn't, it will crack because the threads are sure stress rizors. then it's new case time if you can't weld up/remachine the crack. not all cases have enough meat to do this mod.
Re: mounting a trans cooler [Re: moparx] #1625096
05/30/14 09:50 AM
05/30/14 09:50 AM
I will definitely check that
