The "cross" can be pressed a slight bit forward with the limiting factor being how close the pulley groove is to the (4) mounting bolts and some pulleys have a tapered barrell and some are straight which gives you more clearance but not even close to making up 3/8". I've gone as far as I can without any pics unless something hits me. I'll read thru your OP again & see if something jumps out. Something is drastically out of position for the alignment to be off that far. EDIT Meant to say "rearward" regarding pressing the cross
