Best 1971-1974 B-body Lower Door Panels?
#1624706
05/25/14 10:37 AM
05/25/14 10:37 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Guys, This fall, if funds permit, I may try to get my front door panels put together and finish this darn car up. I know there are quite a few poor quality reproduction molded door panels out there. Who makes the best ones? I always heard that you want 'injection molded' IIRC? I will be needing the seat backs and lower front door panels for my 1973 Charger. Who makes the best ones? Thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Best 1971-1974 B-body Lower Door Panels?
[Re: 72chargerz]
#1624710
05/26/14 08:59 AM
05/26/14 08:59 AM
cjskotni
North Carolina
JAK is correct. There are no good lower panels reproduced for these cars.
They are all terrible.
PALCO may be slightly better than Accuform, but that is not saying much...and most certainly is not an endorsement.
Yeah that's what I was afraid of. ![](/ubbthreads/images/graemlins/frowwn.gif)
Well I have never seen a decent set of the original panels I am going to spend the $$$ on. They all seem chalky and I have a white interior so they are yellowed and don't match the new stuff. Unless NOS just falls into my lap, I have to go aftermarket. I know you can paint them but whatever these are made of doesn't seem to be in too good of shape after 40+ years when you can run your nail over them and they turn to dust.
I just will need to settle for now for the 'best' of what the aftermarket has. I can always swap them later if better panels come my way. ![](/ubbthreads/images/graemlins/thumbs.gif)
Who sells the PALCO? Would you go direct or does YearOne or Legendary sell those?
Thanks!
[Re: JAK]
#1624712
05/26/14 11:44 AM
05/26/14 11:44 AM
Posts: 1,112 sw michigan
TB3CUDA
sw michigan
bought a set of the palco panels for a 73 cuda i had,they are not very nice,they have more plastic in them and do not fit correctly,the drivers side chipped and cracked.the pass side did not fit at all.the original panels have more rubber and are flexable,the repos kinda remind me of model car plastic,and are not flexable at all.i have 3 sets of white door panels front and back that are pretty nice,if you dont find decent repops.and i almost forgot,i paid $700.00 for them cheap plastic cuda panels.only reason i bought them is the car had a blue interior and it came from out west so the panels had all the grain worn off,and turned green.
[Re: steve70]
#1624714
05/27/14 12:51 AM
05/27/14 12:51 AM
Posts: 118 Conyers, Georgia
72chargerz
Conyers, Georgia
Bottom line is that if you want to keep a white interior, you don't have any good options. NONE. Good used ones are basically non existent.
Personally, I chose to ditch my white interior, switch to black and use used panels, freshened up with a very light dusting of SEMS Landau black. Look like new, with correct texture.
Buy the repro's...and you will end up with a Hodge-podge of panel grains and shades of white.
If I absolutely had to keep the interior white, I would buy the lightest color lower panels I could find (probably a light tan/gold set) that were not chaulky...and dye them to match, knowing that they will have to be "touched" up with some regularity. This route is both the cheapest and best looking, but will require maintenance.
