69 dart wiring #1623861
05/22/14 09:58 PM
05/22/14 09:58 PM
mich.
P
purple monster Offline OP
P
mich.
69 DART I have power under the hood but no power in the car ,no lights no ignition nothing inside the car works, only thing I could do was jump starter on solenoid What am I missing ?
Re: 69 dart wiring [Re: purple monster] #1623862
05/22/14 10:04 PM
05/22/14 10:04 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I would start at the wire bulkhead on the firewall.
Try wiggling it to determine if that is the issue.
Was everything working recently?
Re: 69 dart wiring [Re: purple monster] #1623863
05/22/14 10:19 PM
05/22/14 10:19 PM
when you say you have power under the hood you are only referring to jumping the "batt" to the "sol" terminal next to it on the starter relay & it cranked but did not start correct? seperate the bulkhead half that has the fusible link which is the main power going in from the battery & see if you have fire on the eng side bulkhead half brass terminal. Then jump fire to the brass terminal on the other bulkhead half & see if power is restored to the inside of the car & holler back
Re: 69 dart wiring [Re: RapidRobert] #1623864
05/22/14 10:32 PM
05/22/14 10:32 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Is the fusible link gone? Goes from starter relay battery terminal to middle upper slot right hand side connector on B bodys.(A bodys not sure of location) If you had a serious short on inner side of firewall the link will dissintegrate. If so there will be no power to anything.
Re: 69 dart wiring [Re: Pynzo] #1623865
05/23/14 12:46 AM
05/23/14 12:46 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
possible ammeter issue ??? A quick check is to jumper the terminals and see if things start working inside the car. If so you may have a bad or roasted ammeter. Keep in mind that it's a quick test to identify the problem. IE do not expect a 16 ga jumper lead to handle all of the current associated with the crappy desing
Re: 69 dart wiring [Re: TJP] #1623866
05/23/14 01:12 AM
05/23/14 01:12 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Do you have power at the alternator stud? That wire gets power from inside the car.
