what's need to convert my d100 to power steering? #1623613
05/22/14 03:26 PM
05/22/14 03:26 PM
ME
79machocharger Offline OP
ME
My 79 d100 step side is manual steering and I want to convert it over to power. What is needed to do the swap over to power steering. It's a slant six standard on the column.
I have a power steering unit on a 360 80 trailduster 4x4 down back I'm not sure if I can use any thing off of that or not.
It's a bear to steer with the manual steering.
Re: what's need to convert my d100 to power steering? [Re: 79machocharger] #1623614
05/22/14 04:42 PM
05/22/14 04:42 PM
Clinton Twp. Michigan
coronet1966d Offline
Check the post about swapping to manual, why not trade?
Re: what's need to convert my d100 to power steering? [Re: coronet1966d] #1623615
05/22/14 05:29 PM
05/22/14 05:29 PM
ME
ME
Found this on ebay, do these look like the correct ones that I will need?
http://www.ebay.com/itm/Mopar-Slant-Six-...67d&vxp=mtr
Re: what's need to convert my d100 to power steering? [Re: 79machocharger] #1623616
05/22/14 05:33 PM
05/22/14 05:33 PM
ME
ME
I'm going to order a new steering box from advanced and pick up a borgeson steering shaft. Any one know where to pick up the shaft from? Can I go direct and buy it straight from them or is it cheaper to get one some where else?
Re: what's need to convert my d100 to power steering? [Re: 79machocharger] #1623617
05/22/14 06:17 PM
05/22/14 06:17 PM
i got mine from them, just find the part number you need and google it for the cheapest price
Re: what's need to convert my d100 to power steering? [Re: coronet1966d] #1623618
05/22/14 06:39 PM
05/22/14 06:39 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
I didn't have much luck with my generic rebuilt box. Still had quite a bit of play that couldn't be adjusted out.
Just got one from Benchwork Steering in Arizona. They put in oversized BBs to completely eliminate the play, and I think it came out cheaper than the first rebuild I got.
He did say it would have increased steering effort (so the wheel isn't incredibly easy to turn), but it was the same as the old box.
Re: what's need to convert my d100 to power steering? [Re: hooziewhatsit] #1623619
05/22/14 09:40 PM
05/22/14 09:40 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
I would be interested in your old pitman arm and steering shaft if you want to get rid of it
Re: what's need to convert my d100 to power steering? [Re: 6pakdakota] #1623620
05/23/14 11:08 AM
05/23/14 11:08 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I have an almost new power steering hose that I can't use anymore since I went big block. Do you want it? Its specifically for slant six. pm me
Re: what's need to convert my d100 to power steering? [Re: 77ProStreet] #1623621
05/23/14 01:53 PM
05/23/14 01:53 PM
ME
ME
Sure I'm going to collect every thing that I need for the conversion to power steering, pm what you want for it.
