Painting 68 Barracuda Dash Frame #1623603
05/22/14 02:17 PM
05/22/14 02:17 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
It's almost time to paint the dash frame for the 'cuda. I did a search here to see what other people have used and I saw a few posts about SEM Trim Black. How easy was it to spray? Did you need to reduce it? What finish? (I assume satin)
Would the Instrument Specialties paint be better?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Painting 68 Barracuda Dash Frame [Re: Erik] #1623604
05/22/14 02:30 PM
05/22/14 02:30 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I tried to paint my dash frame black with Rustoleum trim paint from a spray bomb. As hard as I tried, I couldn't get the finish consistent enough to satisfy me. I eventually threw in the towel and took it to my local powder coater. He blasted and coated it with semi-mat fine texture powder for $65.00. The frame looks perfect. I probably spent that much money in time and paint trying to do it myself.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Painting 68 Barracuda Dash Frame [Re: FJR doc] #1623605
05/22/14 02:44 PM
05/22/14 02:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think the SEM trim paint is too smooth. I like the Rustoleum Textured paint. Very fine texture.
I've seen a Totally Auto paint from a can shot from a gun and it was way too rough.
Re: Painting 68 Barracuda Dash Frame [Re: autoxcuda] #1623606
05/22/14 02:46 PM
05/22/14 02:46 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
What finish on the Rustoleum?
Re: Painting 68 Barracuda Dash Frame [Re: Erik] #1623607
05/22/14 02:54 PM
05/22/14 02:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't remember if it's offered in different sheens. They have it for cheap at Walmart. Do a test piece and see if you like it and how close it matches virgin original parts of your dash.
Re: Painting 68 Barracuda Dash Frame [Re: Erik] #1623608
05/22/14 03:37 PM
05/22/14 03:37 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Yes. It is the only way to get the true original finish and it must be shot with a gun. Once that dash is installed and the front glass installed it isn't coming out. I would hate to have to live with the wrong finish on my dash for the entire time I own the car. Do it once....do it right!
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Painting 68 Barracuda Dash Frame [Re: autoxcuda] #1623609
05/24/14 10:25 AM
05/24/14 10:25 AM
SE Pa.
LimeliteAero Offline
SE Pa.
anything out of a gun is subject to reducer and air pressure errors along with user ability questions.
Re: Painting 68 Barracuda Dash Frame [Re: LimeliteAero] #1623610
05/24/14 10:36 AM
05/24/14 10:36 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Although out of a spray gun is factory correct, There are many variables that affect the final product. I still think that powder coating is the easiest and more durable option......at least it was for me.
Kevin
Re: Painting 68 Barracuda Dash Frame [Re: FJR doc] #1623611
05/27/14 05:22 PM
05/27/14 05:22 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Who did you use? Lititz is not that far away for me.
Re: Painting 68 Barracuda Dash Frame [Re: Erik] #1623612
05/27/14 07:43 PM
05/27/14 07:43 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used C&C Powder Coating in Ephrata, PA. Their phone number is (717)738-1240. I've had all of my powder coating done by them. I highly recommend their work. Tell them Kevin Miller sent you.
Kevin
