Re: Requesting guidance on a new build....
[Re: Cheatham]
#1623141
05/23/14 08:27 AM
05/23/14 08:27 AM
Posts: 503 Idaho
1320Dart
Idaho
Cheatham- Could you tell me a little more about tour build? I'm all ears and a double chin!
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: moparlulu]
#1623142
05/23/14 08:31 AM
05/23/14 08:31 AM
Posts: 503 Idaho
1320Dart
Idaho
moparlulu- Yes I did. I got it from Cal Percy. Boy did I get the short end of that stick. I'm in Boise
[Re: pittsburghracer]
#1623143
05/23/14 08:36 AM
05/23/14 08:36 AM
Posts: 503 Idaho
1320Dart
Idaho
pittsburghracer- I really have to make each dollar count as well. A lot of people have been telling me that I HAVE to run a vacuum pump. I feel its one more thing in the way and one more thing to go wrong.
[Re: MR_P_BODY]
#1623144
05/23/14 08:46 AM
05/23/14 08:46 AM
Posts: 503 Idaho
1320Dart
Idaho
MR_P_BODY- I hope to get some numbers fairly soon on my heads. I need them anyways to order my Bullet cam.
[Re: 1320Dart]
#1623145
05/23/14 08:06 PM
05/23/14 08:06 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Muscle Motors did my shortblock, flat tops .010 in the hole Ross piston cut for B1 or indy head, the rods and crank are a china brand id have to look up the name but Mike at Muscle Motors has enuff faith in them for what im doing then I have no choice but to rely on it, Heads are 57cciirc and .051 cosmetic gaskets = 15-15.5 compression Bullet solid roller custom grind 7000 rpm max, oil thru pushrods, Jesel rockers, SV1 alky carb, B1 heads I bought used from a member here and were already ported and in the 400cfm range, 727 tranny with CRT internals where needed car is a 73 dart lightened and 4.10 gear converter is a 4800 8in, foot braked, right now im working the coilover mounts and waiting for custom valved front coilovers to arrive, hopefully here soon I can get it finished up.
[Re: Cheatham]
#1623146
05/23/14 08:24 PM
05/23/14 08:24 PM
Posts: 503 Idaho
1320Dart
Idaho
Damn! that sounds so close to my build. you're farther along than I am.
[Re: 1320Dart]
#1623149
05/24/14 01:09 AM
05/24/14 01:09 AM
Cheatham
corpus christi tex
forgot to mention its a world product aluminum block.
[Re: 1320Dart]
#1623150
05/24/14 02:51 AM
05/24/14 02:51 AM
Posts: 771 Btween a rock and a hard place
moparlulu
yep ,Cal is a great guy but your not the first. If you are going to have your heads done, Talk to Wes King . He'll make those heads talk to ya!
[Re: wyoming]
#1623151
05/24/14 02:59 AM
05/24/14 02:59 AM
moparlulu
Sounds like it be a fast dart, when I saw that paint my first thought was Cal Percy, painted just like his cars. Cant believe old Cal would give some one the short end though, well maybe he would I guess.
Glenn, How the hell ya been? Enjoying you new area? Miss seeing your car at firebird.
[Re: 1320Dart]
#1623152
05/24/14 03:20 AM
05/24/14 03:20 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
pittsburghracer- What rod journal size are you using? K1 rods look very nice. I've never held one in my hand. Just seen pics. Have you heard of Molnar rods? I've been kinda checking them out. I would LOVE a set of Corrillo's but my wallet doesn't. I don't like beating the hell out of my stuff either. That's why I've opted to run lower RPM. BTW... how heavy is your Daytona? etc....
Molnar's are nice rods...Iv'e been using them in lots of builds lately
[Re: hemiiroc]
#1623153
05/24/14 05:37 AM
05/24/14 05:37 AM
Posts: 6,142 Melbourne , Australia
LA360
If it was my own engine I would run a 55-60mm camshaft, over the factory journals. Probably overkill at the moment, but if you step it up later you don't have pay more $$$ to have the cam tunnel machined for it. A vacuum pump can always be added later on, I would go with atleast a 0.043" top and second ring anyway, rather than the old school 1/16" ring.
Alan Jones
[Re: jamesc]
#1623154
05/26/14 11:09 AM
05/26/14 11:09 AM
Posts: 503 Idaho
1320Dart
Idaho
I did order it with the larger cam journals. But not the raised cam.
[Re: wyoming]
#1623155
05/26/14 11:12 AM
05/26/14 11:12 AM
Posts: 503 Idaho
1320Dart
Idaho
I didn't think Cal would do that either. Boy was I wrong.
[Re: Cheatham]
#1623156
05/26/14 11:17 AM
05/26/14 11:17 AM
Posts: 503 Idaho
1320Dart
Idaho
I ordered a KB block in January. I'm still waiting.
[Re: hemiiroc]
#1623157
05/26/14 11:21 AM
05/26/14 11:21 AM
Posts: 503 Idaho
1320Dart
Idaho
I'm sure leaning towards them for sure.
[Re: LA360]
#1623158
05/26/14 11:28 AM
05/26/14 11:28 AM
Posts: 503 Idaho
1320Dart
Idaho
If it was my own engine I would run a 55-60mm camshaft, over the factory journals. Probably overkill at the moment, but if you step it up later you don't have pay more $$$ to have the cam tunnel machined for it. A vacuum pump can always be added later on, I would go with at least a 0.043" top and second ring anyway, rather than the old school 1/16" ring.
Yep I did at least order the block with the 54mm cam journals. and I'm split on if I should go 1mm top and second ring or .043.
[Re: Cheatham]
#1623159
05/26/14 03:56 PM
05/26/14 03:56 PM
Posts: 503 Idaho
1320Dart
Idaho
I ordered a KB block in January. I'm still waiting. I'm pretty sure I will run Ross Pistons and Bullet Cam as well. Are you running the 54mm cam? I was going to be using T&D for my rockers. For the crank I've been looking at Ohio Crankshaft.
