17" Tires On a E-Body ? #1622916
05/21/14 01:58 AM
05/21/14 01:58 AM
USA
K
krw71ragtop Offline OP
K
USA
I have a pair of 17X8" wheels for the front and a pair of 17X9" for the rear. Will a set of 275/50's fit on the rear without rubbing ? And how big can I go on the front tires ? This is on a 71 Barracuda with 11" drum brakes, stock width axles, and stock front disc brakes. I currently have 275/60/15" MT Street drags in the rear and no rubbing. And 15X3" in the front (rims). Any pictures would be great.
Re: 17" Tires On a E-Body ? [Re: krw71ragtop] #1622917
05/21/14 02:24 AM
05/21/14 02:24 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I just put 17X9 on my Cuda with 275/40/17 all around. Zero backspacing. There is clearance in the rear. But the fender lips are rolled a bit from my old tires. I'm not positive it will be necessary to roll the lips - it may depend how much you lower the car.
Re: 17" Tires On a E-Body ? [Re: Tom_440] #1622918
05/21/14 10:35 AM
05/21/14 10:35 AM
USA
K
K
USA
Looks good ! The reason why I don't want to use a 275/40/17 is they are 2" shorter than a 275/60/15 according to the wheel chart info here in the tech archives. I don't want go any shorter on the ride height.
Re: 17" Tires On a E-Body ? [Re: krw71ragtop] #1622919
05/21/14 12:34 PM
05/21/14 12:34 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
275 wide tire to calculate width: 275/25.4 = 10.83" wide
The 50 series aspect ratio the tire is 50% tall as it is wide.
10 83 x 50% = 5.415"
Then multiply that x2 for the sidewall on both sidesvof the wheel 5.415 x 2 = 10 83"
17" Wheel + 10.83" = 27.83" tall tire
Do the same with your 275/60 15 tire.
Or use tire rack . Com and look up the specs ofvthe tire you want in a specific size
Re: 17" Tires On a E-Body ? [Re: PHJ426] #1622920
05/21/14 03:03 PM
05/21/14 03:03 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Tire selection in a 17" is sometimes hard to do when you want something kinda wide and kinda tall. The ones I have are probably too big for an E body but they fit a 70 B body. Backspacing on the rear wheels will be the key to the correct fit. Mine are 17x9.5 with 5.5" backspace. Rear tires are 275-60-17. They measure almost 11" wide at the section width and are a full 30" tall. Tread is at 9.5"
...FAFO...
Re: 17" Tires On a E-Body ? [Re: Tom_440] #1622921
05/22/14 02:07 AM
05/22/14 02:07 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Just a guess, but I'm thinking you're meaning zero "offset" rather than zero backspacing on your rims. They look fairly centered - hub-face-to-barrel - so zero offset makes more sense.
BTW, that is a great look: they fill the wells nicely without being visually overpowering. And the proportioning is nice. Well done.
Re: 17" Tires On a E-Body ? [Re: MoparMarq] #1622922
05/22/14 03:14 AM
05/22/14 03:14 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Thank-you.
Yes, I goofed. 5" backspace. O offset.
