Re: Weird clutch problem - whaddya think?
[Re: topside]
#1622353
05/19/14 07:52 PM
05/19/14 07:52 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Take it out on the street with plenty of open road ahead, put it into 1st, depress the clutch pedal, engage the starter....with any luck it'll break loose with the starter alone but, if not, let it start then, with the clutch pedal still depressed, pump the throttle...that should break the disc loose.
