Re: Michigan HEMI CHALLENGE
[Re: warfish]
#162227
05/29/09 11:54 AM
05/29/09 11:54 AM
Posts: 199 wv
j oliverio
wv
Charlie, I think it is great what you guys are doing for the Hemi cars. This type of repore is great for the sport and fans. Although Wild Bill is not racing this year hopefully we will be there in support of the Hemi cars.
[Re: j oliverio]
#162230
05/29/09 07:31 PM
05/29/09 07:31 PM
Posts: 546 mi
warfish
undercover
undercover
mi
Got word from Brian Hard that he will put $2000.00 in the pot!
As far as dates, this is for the Martin Mi event. There will be another event at norwalk in september. Someone from that area may decide to handle that one. The dutch will be handled by Lex Dudas I think. He is a good promoter, and will probably get some good prize money rounded up. cw
hemimilita.com
We are racers, not daycare providers.
Jesel Belt Drive
[Re: warfish]
#162231
05/30/09 12:53 AM
05/30/09 12:53 AM
Posts: 3,505 DFW
mr_340
DFW
Gary Moore broke his Jesel Timing cover on his SS/AH car at the IHRA event here in Dallas today. It looks like the plate was machined or designed to be too thin in the area where it broke out at the cam. Attached is a picture of the cover on the engine.
Floyd Lippencott IV
Re: Jesel Belt Drive
[Re: mr_340]
#162232
05/30/09 12:56 AM
05/30/09 12:56 AM
Posts: 3,505 DFW
mr_340
DFW
Here is a picture of the part that broke out. The material appears to be maybe .010-.020" thick where it broke out. Anyone else have this problem? I was thinking of getting one for the new World block, but I may wait and use the old gear drive until they fix this.
Floyd Lippencott IV
[Re: mr_340]
#162233
05/30/09 07:39 AM
05/30/09 07:39 AM
Posts: 546 mi
warfish
undercover
undercover
mi
I would be curious why they are breaking. There is no load on that part. If there is than your cam is going downhill in the block. I wouldnt say there is a problem until it happens to someone else. I am trying to figure out from that picture what kind of block that is, we have to machine the iron boss around the cam to clear the cover, even on the older blocks. That one has no boss. Its irrelevant, I am just looking for clues. I would say that Gary seems to have a run of bad luck, he handed me a coffe can full of broken valvetrain parts at vegas, and said the valve was bad. I looked at it, the spring was broke, and by the looks of the stem it had been broken for a while. No valve will live under those conditions. These cars are not wind up toys, you have to A)look at everything, and B) know what you are looking for, which most dont. cw
hemimilita.com
Not a wind up toy?
[Re: warfish]
#162234
05/30/09 10:24 AM
05/30/09 10:24 AM
Posts: 753 Louisiana
Spyphish
Louisiana
Man you got that right! Did you know everytime you learn something you get a brain wrinkle? I have added a few so far.
CALMED THE QUAKE!!!(AGAIN!)
Re: 2009 - SS/AH - Super Stock
[Re: meanfish]
#162235
05/30/09 11:37 AM
05/30/09 11:37 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Herb, you might give Erik Jones a call at 1 661 942 3364 about those heads
I second that.
[Re: mr_340]
#162238
05/31/09 09:51 AM
05/31/09 09:51 AM
Posts: 872 NJ
SSDAcuda
NJ
I saw one that broke same way. After checking I found the cam gear drive, was bent. took it to Jesel and they confirmed.
I didn't put it together or run it only saw the parts after.
If cam thrust was right, there shouldn't be THAT much pressure there.
SS/DA 1924
[Re: SSDAcuda]
#162239
06/01/09 06:52 PM
06/01/09 06:52 PM
Posts: 3,505 DFW
mr_340
DFW
How much thrust does the oil pump drive put on the cam? Being mostly a small block guy, does it drive the cam forward or toward the back of the block? It still looked like the material was thinner than I would want. I can't say anything about Gary's engine, but he was racing Hemi's back in the early 1970s, so I would expect he would know his way around them.
Floyd Lippencott IV
[Re: mr_340]
#162240
06/01/09 07:31 PM
06/01/09 07:31 PM
Posts: 546 mi
warfish
undercover
undercover
mi
the cam thrust pushes backwards. That cover could probably stand to be thicker, but I am just saying that if it has happened twice, and it has never happened to anyone I know, and I am on SN 019 for SS/AH motors right now, and have had a belt on every one, that it is probably not an issue. cw
hemimilita.com
rod bolt failure
[Re: warfish]
#162241
06/02/09 03:07 PM
06/02/09 03:07 PM
Posts: 546 mi
warfish
undercover
undercover
mi
this is a pic of heberts motor
hemimilita.com
Re: rod bolt failure
[Re: warfish]
#162242
06/02/09 04:37 PM
06/02/09 04:37 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Charlie is that one of those RBRE non twist rods???
JAKES AUTOMOTIVE
[Re: warfish]
#162244
06/02/09 07:30 PM
06/02/09 07:30 PM
Spyphish
Louisiana
That be me! The other piece never fell in Houston so I hope it did not make it to the ocean?
Re: Another new player...
[Re: cudadoug]
#162246
06/03/09 11:21 PM
06/03/09 11:21 PM
Posts: 546 mi
warfish
undercover
undercover
mi
that is an old mccallum motor that went from cake, to bales, to crosswhite, to kraft. I sold him an oil system, and some carbs. He seems like a pretty nice guy from what I have dealt with him. cw
hemimilita.com
