Valve lash adjustment on a P/B Hemi #1621653
05/18/14 08:36 PM
05/18/14 08:36 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Pretty soon I need to do a hot lash valve adjustment on my Bendix P/B Hemi. 71 cuda.
Will the valve cover clear the brake booster?
Or will I have to loosen the Brake booster and tilt it for the valve cover to come off?
Re: Valve lash adjustment on a P/B Hemi [Re: Topcat] #1621654
05/18/14 10:47 PM
05/18/14 10:47 PM
You might measure how much straight line distance there is between the two as the VC would come up/off at a 45 angle
Re: Valve lash adjustment on a P/B Hemi [Re: RapidRobert] #1621655
05/19/14 03:50 PM
05/19/14 03:50 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Pull plug tubes out first and it will clear.
MLR426
Re: Valve lash adjustment on a P/B Hemi [Re: Topcat] #1621656
05/19/14 05:32 PM
05/19/14 05:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That will depend on what rocker arm set up you have, and type of valve covers?,....it's hard enough with the stock stuff
Re: Valve lash adjustment on a P/B Hemi [Re: DAYCLONA] #1621657
05/19/14 06:41 PM
05/19/14 06:41 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
On my '68 Hemi GTX, I needed the flexible spark plug boot on the #7 wire to get the plug wire off.
I had stock valve covers and rockers.
Stan
Re: Valve lash adjustment on a P/B Hemi [Re: Topcat] #1621658
05/25/14 12:26 AM
05/25/14 12:26 AM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
I was able to do my valve lash adjustment on the driver's side today.
Procedure:
Un bolt master cylinder and tie it with a strip of rag to the hood hinge.
Remove brake booster.
There is no other way to clear it if you run a solid cam with power brakes.
