Re: 604 vs 572
[Re: 1baddart]
#1621652
05/19/14 12:02 AM
05/19/14 12:02 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My 440-1 528 cube motor , single Terminator on alky has gone 8.77 at 153 carrying 3000 lbs, and did it with a roller of 280/288/110 duration, at about1600 Da. Max shift point is7100. You can build it as big as you want but it might be a good idea to keep piston speed in mind. I would think anywhere from 528 to 557 ought to work very well and be a decent split between piston speed and valve train speed. Either can cost you.
