750vs speed demon problem #1621491
05/18/14 08:43 AM
05/18/14 08:43 AM
Pa.
68charger4me Offline OP
Pa.
should it be pulling vacuum at the hole where a secondary shooter would be if it had one?
Re: 750vs speed demon problem [Re: 68charger4me] #1621492
05/19/14 11:49 AM
05/19/14 11:49 AM
absolutely not
Re: 750vs speed demon problem [Re: RapidRobert] #1621493
05/19/14 12:09 PM
05/19/14 12:09 PM
Pa.
Pa.
thanks for the response, i didn't think so. I've always had problems tuning this thing, now I know why. For the meantime I pluged it with a shooter screw. Once I plugged that, the idle cleaned up and my off idle hesitation is gone. Looks like a new carb is in the future lol!
Re: 750vs speed demon problem [Re: 68charger4me] #1621494
05/19/14 12:13 PM
05/19/14 12:13 PM
You might open it up & it likely would be an easy fix (torn/improper gasket etc). I've never seen that & it should be a pretty easy problem to spot once you get inside
Re: 750vs speed demon problem [Re: RapidRobert] #1621495
05/19/14 12:53 PM
05/19/14 12:53 PM
Pa.
Pa.
That's next on the agenda. thanks again.
