What spark plug heat range? #1621275
05/17/14 07:48 PM
05/17/14 07:48 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
I used a NGK -9 heat range for 15:1 compression. Should I change to a -8 for 11:1 and 93 octane?
Re: What spark plug heat range? [Re: Bigcube] #1621276
05/17/14 07:50 PM
05/17/14 07:50 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I would try a -7 first!
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: What spark plug heat range? [Re: 440W8 Duster] #1621277
05/17/14 07:58 PM
05/17/14 07:58 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The Champion C57CX is Perfect...I'm sure if you cross that number over to the NGK you would have the Prefect Heat Range.And at 15.1 CR gap the plugs .022-.025 that will make a Big Improvement.
PS Sorry I mis-read you post that plug is for a 15-1 CR and I have never run a 11-1 CR on 93 octane before.Again Sorry for the mistake.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: What spark plug heat range? [Re: MRMOPAR622] #1621278
05/17/14 11:55 PM
05/17/14 11:55 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I use 9 NGK in my 11.25 cr, SB that has about 205 cranking psi. I run 93 don't here any knock or pinging I think I'm a little rich at idle with a 4 corner idle carb it's mostly a street car. Plugs look a little dark after 3 or 4k but what the h*ll the pistons are still in it!!
Re: What spark plug heat range? [Re: 440W8 Duster] #1621279
05/17/14 11:58 PM
05/17/14 11:58 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
this or a 8
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What spark plug heat range? [Re: Bigcube] #1621280
05/18/14 03:34 AM
05/18/14 03:34 AM
mi
dirty magnum Offline
mi
I used a NGK -9 heat range for 15:1 compression. Should I change to a -8 for 11:1 and 93 octane? [/quote i use 7s for 15:1
i use 7s for 15:1
Re: What spark plug heat range? [Re: dirty magnum] #1621281
05/18/14 04:04 AM
05/18/14 04:04 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mancini had a good NGK heat range to CR chart but I can't find it on there site maybe someone has it.
Re: What spark plug heat range? [Re: ademon] #1621282
05/18/14 09:00 AM
05/18/14 09:00 AM
ill
dennismopar73 Offline
ill
Why change heat range ?
Fix issues x motor to fat. Repair carb or fuel.delivery
Getting oil contaminant in combustion chamber , fix it
Heat range is only the temp that the plug disperse to keepit firing.
Not actual cyl.temp
Not all plugs heat rang alike
NGK
http://www.ngksparkplugs.com/tech_support/spark_plugs/p2.asp?mode=nml
