Big block water pump rebuild
#1621179
05/17/14 01:52 PM
05/17/14 01:52 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I would like to get my stock water pump rebuilt, does anyone know of a company that does rebuilds them. Also is there a difference between a standard water pump and one for A/C? This is Arizona and if an A/C pump cools better I would like to go that route.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Big block water pump rebuild
[Re: AZ_A12_BEE]
#1621182
05/17/14 10:59 PM
05/17/14 10:59 PM
Thought A/C water pumps had 6 blades and non A/C cars had 8 blades on the impeller.
[Re: ]
#1621183
05/18/14 03:52 PM
05/18/14 03:52 PM
Posts: 25,806 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yep, A/C has 6 vanes and smaller diameter impeller, non-A/C has 8 vanes and larger diameter impeller.
[Re: AZ_A12_BEE]
#1621185
05/18/14 03:57 PM
05/18/14 03:57 PM
John_Kunkel
Rio Linda, CA
You're more likely to get the correct impeller from a rebuilder than from an auto supply. Most auto supplies now sell the 6-vane for all applications.
[Re: AZ_A12_BEE]
#1621186
05/18/14 03:59 PM
05/18/14 03:59 PM
AZ_A12_BEE
Dreaming of the 808
Is that 168H on the end of the snout a date code and if so what date is it?
37 Plymouth PU
