Page 3 of 10 1 2 3 4 5 9 10
Re: Whats left of a 8 3/4 aluminum center [Re: CMcAllister] #1620909
05/18/14 02:10 AM
05/18/14 02:10 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
As much as this will "irk" the faithful here.....I would NOT put a Dana in a drag radial, small tire car. The housing is too long and too weak. It WILL bend and there is no decent way to brace a Dana housing. Bends the ends forward and not a whole lot you can do about it
Monte
Re: Whats left of a 8 3/4 aluminum center [Re: CMcAllister] #1620910
05/18/14 02:35 AM
05/18/14 02:35 AM
Baltimore,MD
Bill_LBSR Offline OP
Baltimore,MD
I'll bet the track crew was PO'd. That makes a nasty mess to clean up on a starting line. Don't ask me how I know.
He pulled off to the side as soon as it happened. It was test and tune night and not that crowded so it wasn't too bad.
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Monte_Smith] #1620911
05/18/14 02:41 AM
05/18/14 02:41 AM
Baltimore,MD
Baltimore,MD
Monte
What would you recommend him putting in it, Monte?
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620912
05/18/14 02:47 AM
05/18/14 02:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A 9" with a GOOD housing........meaning a chromoly housing
Monte
Re: Whats left of a 8 3/4 aluminum center [Re: Quicktree] #1620913
05/18/14 02:52 AM
05/18/14 02:52 AM
iowa
W
weinerboy1 Offline
weinerboy1  Offline
W
iowa
We have weiner dogs.
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620914
05/18/14 03:04 AM
05/18/14 03:04 AM
Baltimore,MD
Baltimore,MD
I'll let him know, Monte. Now you have me worried about the Dana in my car....lol.
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620915
05/18/14 03:06 AM
05/18/14 03:06 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Which car was this in? Y'all have some nice darts
Re: Whats left of a 8 3/4 aluminum center [Re: Monte_Smith] #1620916
05/18/14 12:37 PM
05/18/14 12:37 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Weight and torque is what kills an 8.75. P-body could put a big block in that thing or spray the small motor and it will snap that case like a twig.
It just doesn't matter what you do to them, you can't fix the inherit flaw in the design. The gear end of the pinion is NOT SUPPORTED. The pinion flexes, comes away from the ring gear....saws teeth off and that clogs up the works and SOMETHING has to give and that is usually the case. Housing flex is NOT what kills them, it is pinion flex. Better cases, billet caps and all that other stuff is like a bandaid on a gunshot would. Not much help
As for the OP.......the ONLY thing that is going to survive in a decent HP radial car is a Dana or a 9". RADIALS BREAK CRAP. We have a chromoly housing in our radial car and bent it several times. The new housing is also chromoly, but has .250 wall axles tubes and is braced like you would for a Pro-Mod car.......2800lbs, dead hooking tire and going 1.0 60fts STRESSES parts
Monte
I'm confused, how is the rear of the pinion supported differently than a Dana? Just trying to understand.
Re: Whats left of a 8 3/4 aluminum center [Re: B1MAXX] #1620917
05/18/14 01:06 PM
05/18/14 01:06 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A 9" has an extra bearing, it's on the end of the pinion shaft. So there are three bearings on the pinion. A Dana has a big pinion shaft and strong housing that doesn't flex like a 8 3/4 will.
Re: Whats left of a 8 3/4 aluminum center [Re: justinp61] #1620918
05/18/14 01:25 PM
05/18/14 01:25 PM
Apollo, PA.
Apollo, PA.
I get the support for the 9". But the 8.75 has a larger dia. pinion than a Dana as I recall.
Re: Whats left of a 8 3/4 aluminum center [Re: justinp61] #1620919
05/18/14 01:26 PM
05/18/14 01:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
a dana is stronger than an 83/4 but they will flex also.
"As much as this will "irk" the faithful here.....I would NOT put a Dana in a drag radial, small tire car. The housing is too long and too weak. It WILL bend and there is no decent way to brace a Dana housing. Bends the ends forward and not a whole lot you can do about it
Monte "
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620920
05/18/14 02:48 PM
05/18/14 02:48 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Stock suspension on 275s. Car weighs around 3300. Looks to me like the ring gear came apart and then jammed everything up causing the case to crack. But that's just speculation on my part.
I would agree, once those broken off teeth run back between the gears a second time, stuff has to go somewhere. I had an S case 9" third member that looked exactly like that.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Whats left of a 8 3/4 aluminum center [Re: MoparBilly] #1620921
05/18/14 02:57 PM
05/18/14 02:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I sheared a set of 4.30 gears at the line @ Norwalk and never broke the staging beem. Lots of runs on those gears in a well built 9 inch so racers can and do break EVERYTHING given time and enough horsepower.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Whats left of a 8 3/4 aluminum center [Re: MoparBilly] #1620922
05/18/14 03:04 PM
05/18/14 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a 9" in the Rampage... supposedly its got a
better 3rd member and a good support... my buddy told
me what the 3rd member was but I forgot what he said...
plus I went to some Detroit posi unit(not the locker
that clicks) and the housing is back braced so I expect
it to live just fine... right now its only 590hp
but I am looking to build a TT gen3 down the road
Re: Whats left of a 8 3/4 aluminum center [Re: pittsburghracer] #1620923
05/18/14 03:27 PM
05/18/14 03:27 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
ANYTHING.......CAN be broken, that is a fact. But it is also a fact that a 9" can be built into a MUCH stronger drop out style rear than an 8.75, as witnessed by the fact being that is the rear of choice under 99% of high HP race cars on the planet. The fact that ANY of those parts may or may not be an original Ford part is a moot point. It is a Ford design.....it's a 9" Ford.
The reason a DANA holds up better than an 8.75 is just because of the massive size and strength of the center section itself. The case will not flex near as much in the pinion area, even without the support bearing of the 9".
While the center strength of the DANA is a plus, its rear load design is a weakness. It is IMPOSSIBLE to properly brace the housing itself, to keep IT from flexing and bending the axle tubes. If the tubes have any length to them, they WILL bend and you can't stop it.
Any of this has ZERO to do with if you are a TRUE Mopar guy or not, it has to do with putting the proper part under your car to do what YOU need to do and it last.
Radials are HARD on parts. The tire is hooked or its not. There is no in between. You CAN'T spin or slip a radial and it still go down like a slick. A Radial DEAD HOOKS and THAT is hard on parts with a lot of power. You will bend or break EVERYTHING in the drive line if it is not beefy enough.
In our own radial car, that weighed about 2900lbs, we had a VERY well built Moser mild steel housing, that was heavily braced. The car was 60 footing in the high teens to low 20 at that time. We bent the housing 3 times. When the car got hard to push, we knew the tubes were bent. It would bend them out at the ends. Have seen it bent as much as an inch per side. Once you got the axles out, they did NOT go back in. We now have a chromoly housing, with .250 wall chromoly tubes and it is braced and built like you would a housing in a Pro-Mod. The car now goes 1.0 60fts at 2700lbs and we have NOT bent that housing. We have 40 spline gun drilled axles, a pro series spool, pro gears and both a Mark Williams or a Strange thru bolt case, depending on what gear we run. Expensive parts......yes..........but we have NEVER broken a gear or anything rear end related.
NOW........does EVERYBODY need the parts we have, of course not. What YOU need, depends on what you plan to do. My issue is with the constant "put a Dana under it" chatter every time this subject comes up. While a great rear for some applications, for others it is DEAD WRONG. And for a 3000lb radial car, that has the potential to go low 5s, like the two cars Bill is talking about. A DANA is the WRONG choice..........period.
Just because you broke an 8.75 in your 9 or 10 second car and "fixed" it with a Dana, does NOT mean that is what everybody needs to do. The proper parts are application specific
Monte
Re: Whats left of a 8 3/4 aluminum center [Re: Monte_Smith] #1620924
05/18/14 03:45 PM
05/18/14 03:45 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
What I've learned from Monte's rant:
I can live with the 9" Ford under my Valiant.
I can live with the Dana 60 under my Barracuda.
Maybe the rear ends aren't the wrong choice, maybe going 1.teens at 2900lbs or 1.0h's at 2700lbs on a small tire is the wrong choice! Just because you CAN, doesn't mean you should!!
Carry on.
I'm glad someone is out there constantly pushing the edge, so that I can learn what works and what doesn't without shredding my wallet in the process!
Re: Whats left of a 8 3/4 aluminum center [Re: Monte_Smith] #1620925
05/18/14 03:52 PM
05/18/14 03:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
Mods you need put that in the best of section
Re: Whats left of a 8 3/4 aluminum center [Re: MoparBilly] #1620926
05/18/14 03:59 PM
05/18/14 03:59 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Carry on.
I don't even know what that means.........so it appears you are saying we are wrong, to try to go as fast as we can and get as much as we can, from a car we run in a "heads up" class................hmmm, interesting observation.
Monte
Re: Whats left of a 8 3/4 aluminum center [Re: Monte_Smith] #1620927
05/18/14 04:35 PM
05/18/14 04:35 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Monte,
I was being sarcastic!
I am constantly in awe of the advances being made in the heads up classes, and many of us are indebted to those who are willing to spend the sweat, time, effort, and dollars to go that fast. The trickle down from those hard earned lessons is that everyone has the opportunity to step up their program with better, more reliable parts.
If they choose to take off their blinders, and pay attention...
Re: Whats left of a 8 3/4 aluminum center [Re: MoparBilly] #1620928
05/18/14 04:54 PM
05/18/14 04:54 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I wouldn't consider anything BUT a fabricated housing in a serious effort deal.....especially a heavy drag radial car.
Racecars are hard enough on parts as it is, so why the heck would anyone roll the dice and in the end, have to spend twice (at least) when the compromised part is on borrowed time from day one???
It always costs more in the long run and sometimes hurts more than just the affected part, like in the case (no pun) of a severe transmission explosion.
When it comes to rears and transmission, there are so many good choices in aftermarket race "style" solutions.....at reasonable cost, it doesn't pay either in money, or safety to play games.
