Page 1 of 10 1 2 3 9 10
Whats left of a 8 3/4 aluminum center #1620869
05/16/14 11:22 PM
05/16/14 11:22 PM
Baltimore,MD
Bill_LBSR Offline OP
Baltimore,MD
Drag radials and nitrous took its toll on this aluminum 8 3/4
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620870
05/16/14 11:22 PM
05/16/14 11:22 PM
Baltimore,MD
Baltimore,MD
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620871
05/16/14 11:23 PM
05/16/14 11:23 PM
Baltimore,MD
Baltimore,MD
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620872
05/16/14 11:29 PM
05/16/14 11:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Oh SNAP!! what's on the platter next?
......did you REALLY think it was going to last?
Re: Whats left of a 8 3/4 aluminum center [Re: J_BODY] #1620873
05/16/14 11:41 PM
05/16/14 11:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no matter what you do to them they are still 83/4s
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620874
05/16/14 11:43 PM
05/16/14 11:43 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Hp+ radials alone will bust them eggshells..
Re: Whats left of a 8 3/4 aluminum center [Re: J_BODY] #1620875
05/16/14 11:51 PM
05/16/14 11:51 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
A couple of people in my club are still stressing the 8.75 rears. I offered the older one my Dana 60 that I narrowed with a PowerLock 4.10, 35 splines axles. The rear was narrowed to fit my '87 and the only drawback to the deal is that the bolt pattern is 5 on 5.5" and the brakes are 12" drum. So buy some 16" wheels with the big pattern and run ProStock slicks, no problem. His son turned me down on Facebook saying "...we will never break the 8.75...". The kid has already exploded a 727, but "...he will never break an 8.75...". I used to think I had all the answers, too until I realized I did not even know all the questions
And no, I have no idea what their 60 foots are. I do know they are still running the SBP axles
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620876
05/17/14 12:07 AM
05/17/14 12:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I still have my alum center.... I have 1 question
for the OP... did both caps have full threads in them...
I know of a few that were sold that had very shallow
threads in one side or the other
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620877
05/17/14 12:39 AM
05/17/14 12:39 AM
Baltimore,MD
Baltimore,MD
Not mine, its out of friends car. Lasted for long time foot braking. That was probably the the 7th or 8th pass using the trans brake.
Not sure about the threads Mr. P Body. That center section has been in the car for years. Probably would have stayed together foot braking, trans brake was too much for it.
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620878
05/17/14 12:48 AM
05/17/14 12:48 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So if it was iron would it have survived? I mean is the case the weak link or did something take the case out.............
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620879
05/17/14 12:48 AM
05/17/14 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been hitting mine with the transbrake for years
now... whats the car race weight
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620880
05/17/14 12:54 AM
05/17/14 12:54 AM
Baltimore,MD
Baltimore,MD
Stock suspension on 275s. Car weighs around 3300. Looks to me like the ring gear came apart and then jammed everything up causing the case to crack. But that's just speculation on my part.
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620881
05/17/14 01:04 AM
05/17/14 01:04 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Housing flex can use the axel as a pry bar and bad things happen. At launch The wheels cause the housing ends to Bananna forward and POP!
I finally went to a Moser Dana and forgot about it. I use the trans break every pass now.
Re: Whats left of a 8 3/4 aluminum center [Re: FastmOp] #1620882
05/17/14 01:36 AM
05/17/14 01:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont worry about that, I'm back braced and I tell
everyone to back brace a 8 3/4 or a 9"
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620883
05/17/14 02:20 AM
05/17/14 02:20 AM
Baltimore,MD
Baltimore,MD
Housing was back braced. Yeh hes going to put a Dana in it.
LBSR
Re: Whats left of a 8 3/4 aluminum center [Re: Bill_LBSR] #1620884
05/17/14 02:39 AM
05/17/14 02:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Was he hosing it right on the launch... how much
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620885
05/17/14 02:54 AM
05/17/14 02:54 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Don't matter........on radials and spray, it never had a chance. Surprised it lasted as long as it did. You can back brace the housing to the moon and back, that don't help the weak case.
Monte
Re: Whats left of a 8 3/4 aluminum center [Re: Monte_Smith] #1620886
05/17/14 03:14 AM
05/17/14 03:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
Well I'm glad I run slicks and dont spray... mines
doing fine... the alum case is supposedly 20% stronger
than the iron one and mainly due to the bolt through
caps
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620887
05/17/14 08:22 AM
05/17/14 08:22 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Monte
caps
Mike..... Get real..... Lol
Your lasts because the car doesn't weigh anything, and you hardly ever get it out to race. That's why it lasts... Lol
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Whats left of a 8 3/4 aluminum center [Re: MR_P_BODY] #1620888
05/17/14 09:38 AM
05/17/14 09:38 AM
Guitar Jones Offline
Three of those bolts are through the case and the fourth is a stud. What threads are you talking about?
