Parking light ? #1620865
05/16/14 10:41 PM
05/16/14 10:41 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
I have a 71 Demon, the parking light bulbs are really dim. You can barely tell it is lit with the lens off. The signals work fine. I changed the bulbs and that didn't fix the problem and it seems to be grounded good. The horn doesn't work either and they come of the same harness. thanks for your help
Re: Parking light ? [Re: b5a12bee] #1620866
05/16/14 10:48 PM
05/16/14 10:48 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Use a voltmeter and measure the voltage..
Sounds like it is on low side...
Just my $0.05....
Re: Parking light ? [Re: b5a12bee] #1620867
05/16/14 11:17 PM
05/16/14 11:17 PM
With the lens off run a jumper from the batt neg post & touch the edge of the brass bulb case with it in the socket & lit up, with a thin needle probe to see if it is a ground side or power side resistance problem. Ground side issues are more common but you said the large filament ts/brake lights work fine. It can feed back thru the other filament but post what you get
Re: Parking light ? [Re: RapidRobert] #1620868
05/17/14 12:03 PM
05/17/14 12:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with RR sounds like a ground problem.Rocky
Chrysler Firepower
