Comp springs #1620771
05/16/14 07:30 PM
05/16/14 07:30 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Going to a roller cam this year in my 500 ci Eddy headed, tunnel ram bracket motor and engine builder says I need Comp springs #943-16. Wondering if I should step up to an even better spring or are the Comp springs good enough?? If I should step up, too what mfg. and part#??
As I said bracket motor that I race about 7-8 times a year and usually stay under 7000 rpm.
Derrick
Re: Comp springs [Re: Hyper Henry] #1620772
05/16/14 08:23 PM
05/16/14 08:23 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
943's are a good spring in the right application. i run a roller in the 270's@050 with 650 lift & they've lasted 3 seasons reving to 7300 before we detected valve bounce on a set of -1 indys. when i stepped up the cam with 280's@050 those springs didn't last as long. by the end of the first season we were detecting valve bounce so we had to step up the springs. they're easy on the rocker gear, even Indy's ali cheapies.
