media blasting body to prepare for resto #1620747
05/16/14 07:21 PM
05/16/14 07:21 PM
Long Island, NY
shakerjoe Offline OP
Long Island, NY
I spoke with a media blaster today who recommended crushed glass to media blast my car, (first one I spoke too) he came to my house today and seemed pretty thorough and knowledgeable - said it wouldn't heat up the panels and would leave a good surface for the body shop. Key for me is he's very local and price didn't seem offensive - he would also remove doors to get the jambs, said baking soda would leave surface too smooth, and doesn't use sand for auto or boats - appreciate any thoughts or other questions I can ask - quoted me $800.00 - TIA - Joe - website : www.srs-ny.com
Re: media blasting body to prepare for resto [Re: shakerjoe] #1620748
05/16/14 07:52 PM
05/16/14 07:52 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I see no difference between glass and sand, both are silica based and will warp your panels
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: media blasting body to prepare for resto [Re: AZ_A12_BEE] #1620749
05/16/14 08:13 PM
05/16/14 08:13 PM
Long Island, NY
Long Island, NY
mmm, good point, thanks - will keep that in mind when I talk to him again, keep 'em coming!
Re: media blasting body to prepare for resto [Re: shakerjoe] #1620750
05/16/14 08:16 PM
05/16/14 08:16 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
what exactly on the car is he blasting?
800 sounds cheap to me..
does he come to jersey? lol
i use a fine slag 40/80 i think ? that leaves a little bite for the epoxy primer
unless its really rusty then i step up to coarser grade 30/60
i only blast on the flat panels as little as possible
so i don't have to sweat warping or overheating anything.
i never tried glass,it didn't seem economical for the price
i have found it at to be able to try it.
Re: media blasting body to prepare for resto [Re: flypaper] #1620751
05/17/14 11:21 AM
05/17/14 11:21 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I found plastic media to be the best. I used this on my Superbird resto. Had the whole car done, including removal of all the undercoating.
For my cureent Cuda resto, i found someone who uses powdered (not crushed) glass at low pressure. Even it will warp panels if not careful.
If I do another car, it will be done using only plastic media.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: media blasting body to prepare for resto [Re: RealWing] #1620752
05/17/14 09:09 PM
05/17/14 09:09 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
In my opinion there is no single media which will effectively strip an entire car for restoration. You need plastic or soda for the paint and bondo but neither will touch rust so you need sand, glass or granite for that. But even then, rust is so fine that no media can be guaranteed to get it all so you need to acid wash those area afterwards.
Most blasters I talk to will do the blasting then an epoxy prime as a package deal. This concerns me because they're potentially covering up what they couldn't blast out.
Re: media blasting body to prepare for resto [Re: Stanton] #1620753
05/17/14 09:54 PM
05/17/14 09:54 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I have posted on this before. I am a media blaster and specialize in sheet metal blasting.
first off. stop listening to people who know only what they read on the internet and have no first hand experience in blasting cars. a logging truck isn't a car and doesn't use the same media. Go see your blaster and have him show you what he can do with a donor part. I do this all the time for people who believe old school myths about media and warpage. most of the time they say "wow"
sand and glass are NOT the same. sand is garbage.
I am a multi media blaster and will choose what is best for your car and for the most bang for the buck. we use soda, walnut 3 grits of glass (200 100 20-50) aluminum oxide, 2 types of garnet never sand. most projects other than hoods and trunk lids are now done with glass. this includes corvettes.
price $800 is fair. I would be around that as well.
vette 200 grit glass.
caddy (yep caddy) 100 grit
nomad 100 grit
how about a beer can?
please pm me if you have any questions on blasting . I take pride in my work and don't care if its a $10 part or the $150,000 31 caddilac I did.
Re: media blasting body to prepare for resto [Re: chrisf] #1620754
05/17/14 10:00 PM
05/17/14 10:00 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
oops no mopars.
hemicuda
Re: media blasting body to prepare for resto [Re: chrisf] #1620755
05/18/14 12:20 PM
05/18/14 12:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I learn something from your posts every time I read one.
I also have been blasting a long time, mostly trucks that any monkey can do. I have done cars also.
I agree with one of the posters above, multi able medias are required for a different parts of the car.
Reason for my post is to point out that I like using a steam pressure washer on the whole car first before any blasting takes place.
It removes ALL body seam sealer, oil, grease, road tar, rubber AND ALL undercoating. It does not remove any factory paint. It will remove aftermarket paint jobs if I want it to. I use it to remove 2nd and 3rd paint jobs from jambs so I can see the spotwelds to drill out and do not have media everywhere to work around. Plus it does not flash rust like bare metal does after blasting.
Then I can see what I really "have" before blasting.
That way it requires way less blasting to remove the factory paint coatings and not stress the metal any more than necessary by not blasting off undercoating with media.
FWIW I use coal slag on the bottom, insides and plastic media on the outside body panels.
I'm sure the glass is better than slag, but I'm wondering what the price difference is. Last time I looked it was a lot more than slag. I bet slag is like sand to you? I'm going to try some glass here soon on my next delicate job, thanks.
I would never use slag on the outside body panels.
I used the pressure washer on this car before blasting, removed all the seam sealer inside and the aftermarket black paint job in the jams so I could see the spot welds to drill them out. No bare metal to rust while I do rust repair like if I were to media blast first and no media to clean up or work around.
Found a factory spotweld tip attached to my car.
Re: media blasting body to prepare for resto [Re: chrisf] #1620756
05/18/14 01:18 PM
05/18/14 01:18 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
I've said before that I wish I lived closer to you. Blasters around here don't come close to your price. And from what little experience and knowledge I have I honestly don't know how you can do it that cheap when you have to switch medias, etc..
Out of curiosity, where would you use the walnut ???
Maybe, if you don't mind, give us an idea of where each of those medias listed would be used.
Re: media blasting body to prepare for resto [Re: Stanton] #1620757
05/18/14 02:14 PM
05/18/14 02:14 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've been using fine sand for over 20 years to blast cars and I've never had a panel warp. The worst part is the clean up. I see no reason to switch to anything else more expensive when it works perfectly fine. It's like using a grinder or anything else, you stay on one spot too long, it's going to heat up and warp... it's really not rocket science
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: media blasting body to prepare for resto [Re: chrisf] #1620758
05/18/14 03:01 PM
05/18/14 03:01 PM
Cincinnati, Ohio
Cincinnati, Ohio
oops no mopars.
hemicuda
Looks good, but I would never blast it with hinges in place. Even if the owner left them in place, I would insist on him removing them. So he can't blame me for his messed up hinges down the road if he don't take them off and rebuild them after blasting. Then you got nasty dirty metal under them when you do take them off for rebuilding.
Re: media blasting body to prepare for resto [Re: Challenger 1] #1620759
05/18/14 09:03 PM
05/18/14 09:03 PM
IL
Rawone Offline
Rawone  Offline
IL
Just got my roadrunner soda and media blasted yesterday. this is how she turned out. no heat distortion web page
Re: media blasting body to prepare for resto [Re: Rawone] #1620760
05/18/14 09:31 PM
05/18/14 09:31 PM
Long Island, NY
Long Island, NY
I appreciate all the input - thanks ChrisF - I am a one car owner, one car garage, one time at this - guy with a rare car that I cannot afford to have something blow up in my face - hence my trepidation - been collecting parts NOS and mint used and restoring in the meantime for my one shot - or contemplating on selling and picking up something else - but the restoration juices flow - I just have to cover all the bases because obviously nobody likes to take a hit, I just cannot afford to...keep 'em coming - thank you, Joe
Re: media blasting body to prepare for resto [Re: shakerjoe] #1620761
05/18/14 11:40 PM
05/18/14 11:40 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
ok...
you have a RARE car that means ALOT,or i would not of bothered to preach any of this dribble if not for your last post.
i've learned alot about blasting from seeing other
peoples work first hand and also seeing other peoples very bad mistakes.
it is alot easier then some here think to screw something up.
i think you should at least know some basic fact to know
about blasting that nobody here even mentions to you before jumping in...
one thing i do know is when you blast metal is
you are changing the surface definition of the metal and
also you are taking away the finer details and wrinkles.
the amount of that change will depend alot on media selection and blast method.
when you blast something,
you are streching/fatiguing the surface of the metal, even if you can't see it when your done!
no matter what media you choose to use...
you might not warp the panel,but you have changed the surface,streched/fatigued/ effected the metal in some way!
it is one of the main reasons why i choose not to blast much on the outside flat panels.only in areas where its needed.
i do not want to lose any of the finer details
or definition in the area where everyone's eyes are upon it.
also that isn't a area where most of the rust is anyway,
so why strech out/fatigue the metal in a area when you don't need to??????
just because it takes the paint off easy
is the wrong reason...........
imo
i feel that you should really only blast where you really have to, the inside and underside and leave the outside
for the chemicals.
consider my method ,it is fool proof and
you take no risk of irreversable damage happening.
you have a RARE car,
why take the chance?
this is just my anal andyness opinion coming out
and how i see it
and some food for thought for you.
i really don't care what you do,
but you can't say there isn't a method to my madness
Re: media blasting body to prepare for resto [Re: flypaper] #1620762
05/19/14 12:07 AM
05/19/14 12:07 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
Flypaper. You may want to stop using sandpaper if your that concerned about surface damage. Your overthinking the process. Go look at my beer can pic. Zoom in on it and then go cut open a beer can and measure it. Everybody has their own way of doing things but I think your doing more work than necessary.
Re: media blasting body to prepare for resto [Re: chrisf] #1620763
05/19/14 01:11 AM
05/19/14 01:11 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
maybe overthinking or maybe too much work,but
i learned alot in the past from one of the very best in the restoration game ...
what can i say,it rubs off...
i full well know what blasting does/can do to metal...
you can't deny
the surface of that can has been changed from what it was.
it was very very smooth,now the surface is roughed up.
you might not be able to measure any change in thickness when you cut it open, but
i'd be willing to bet if it was pressure tested against another can, the blasted can would be weaker and would burst first
Re: media blasting body to prepare for resto [Re: flypaper] #1620764
05/19/14 01:22 AM
05/19/14 01:22 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
You definitely don't want to shake a beer that's in a can that's been blasted !!!!
Re: media blasting body to prepare for resto [Re: Stanton] #1620765
05/19/14 01:37 AM
05/19/14 01:37 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I can paint a piece of glass and soda blast off the paint with no damage to the glass so if ANY media blasting damages the substrate why isn't the glass white or broken?
Stanton. The beer can is smooth no damage. Shake all you want. Soda isn't abrasive it doesn't cut. the surface is 100% how it came from the factory before paint
Re: media blasting body to prepare for resto [Re: chrisf] #1620766
05/19/14 02:41 AM
05/19/14 02:41 AM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
Chris, what are using on the underside to remove rust and undercoating?
